Monitoring transmission pressure - TCCoA Forums
post #1 of 6 (permalink) Old 02-07-2007, 05:54 PM Thread Starter
TMW
TMW's Avatar
Question Monitoring transmission pressure
How bad would it be to drive around with pressure gauges hooked up permanently to the transmission (all taps)?
I seem to remember reading in a Ford manual that "transmission failure could result" because it "may affect shift quality".
Is it really (potentially) that bad or were they just covering their asses?
Tom
TMW is offline
post #2 of 6 (permalink) Old 02-08-2007, 07:59 PM
3rd Gear Chirper
hotbird's Avatar
Why would it affect shift quality? Installing a gauge is just like installing the plug that is normally there back in the port...they are both "dead ends" and will not let fluid pressure escape.
hotbird is offline
post #3 of 6 (permalink) Old 02-08-2007, 08:47 PM
tbirdbrain's Avatar
My AOD is about to have a sender shoved right up its tv pressure port as a permanent fixture. No harm in doing it as long as the senders remain in tact.
tbirdbrain is offline
post #4 of 6 (permalink) Old 02-08-2007, 08:50 PM
The Great Obucina's Avatar
sounds kinda kinky.
"Booyah". Stu Scott.
The Great Obucina is offline
post #5 of 6 (permalink) Old 02-08-2007, 10:28 PM
I have one on my Tbird so I can adjust the TV, the right way.....
Lonnie is offline
post #6 of 6 (permalink) Old 02-09-2007, 07:35 AM
I bent a cheap 100psi gauge on my t.v. port when goosing the throttle If you permanantly install a gauge make sure it's rated for 500 psi spikes without damage. An electronic sender would be ideal.
icantdrive55 is offline
