i fixed my trans with this... - TCCoA Forums
post #1 of 19 (permalink) Old 02-09-2007, 08:05 PM Thread Starter
rednsilver94sc's Avatar
Send a message via AIM to rednsilver94sc
well i posted early saying my trans was toast it would shudder horribly engaging each gear at low rpm, so i decided to take one last gamble before putting a new tranny in it
i went to autozone and purchused the trans filter and gasket and made a quick stop at Tractor supply center
i bought a 2 gallon container of Tractor transmission/hydraulic fluid for most tractor applications and i proceded in changing the filter and topping the trans off
i put about 100 miles on the car today and it shifted beautifly and never shuddered one time im very pleased and i figured id pass this note along to anyone else in my current situation
rednsilver94sc is offline
post #2 of 19 (permalink) Old 02-09-2007, 08:08 PM
Had you tried mercon 5 fluid before going to the tractor stuff? I don't know what kind of a long term effect using the tractor fluid will have on the trans, but the merc 5 was specifically designed to eliminate shudder on these transmissions, so if it were my car, I would go with that.
Mike
PS. If the merc 5 doesn't solve the shudder, you would only need to replace the torque converter, not the whole trans.
MadMikeyL is online now
post #3 of 19 (permalink) Old 02-09-2007, 08:16 PM Thread Starter
well if i was going to drop the trans to even replace the tourqe converter i would have ended up rebuilding the transmission as well in a few thousand miles or so more like next winter i had planned to rebuild the trans and do a pi swap to the car
so this was more like a 1 year fix i suppose the fluid is definitely thicker then mercron 3 no i did not switch to mecron 5 i had changed the fluid one time 5-6k miles ago prolly last year with 75k mile plus fluid to see if that would fix and it didnt help at all
i did notice my trans crossmember bushings were toast so i have to order a set of those as well
post #4 of 19 (permalink) Old 02-09-2007, 09:08 PM
Darrin's Avatar
Well I hope that works out for you.
Darrin
Darrin is offline
post #5 of 19 (permalink) Old 02-09-2007, 09:16 PM
I dunno about that. I'm all for tractor fluid in a few transmissions. With non lockup applications it helps with a few things. On a 4r70w I am concerned for your electronics and converter clutch. Shudder can be eliminated 2 different ways. Either get the fluid in it right and the clutch will stop slipping lightly (shudder) or put the wrong fluid in it and the clutch will slip so bad it doesn't shudder anymore.
post #6 of 19 (permalink) Old 02-09-2007, 09:34 PM
We get buckets off that stuff at my job from napa, I believe its tractor hidro fluid / auto trans. Ive heard people doing this & that it improved the shifting but I think it runs hotter then ATF???
PReDiTR91 is offline
post #7 of 19 (permalink) Old 02-10-2007, 12:45 AM Thread Starter
im happy with it just took it out for a little fun few spurts where i got blown away by a gtp but the car shifts smooth as can be
i dont see why it would run hotter tractor transmissions deal with alot more tourqe then a automotive transmisson
post #8 of 19 (permalink) Old 02-10-2007, 02:12 AM
I didn't say it would run hotter. MerconV fluid is highly friction modified semi synthetic fluid. It's coefficient of frictions is completely different from standard atf or hydraulic oil. The only increase in heat I could see would be from extra converter clutch slippage due to fluid that is "slicker" than the normal fluid. If you sample the fluids in your fingertips you will feel the difference. MerconV does taste better as well, until it's burnt. Not as good as antifreeze, but considerably better than brake fluid.
post #9 of 19 (permalink) Old 02-10-2007, 09:34 AM
Ain't that the truth.
FordMan77 is offline
post #10 of 19 (permalink) Old 02-10-2007, 09:52 AM
Darrin's Avatar
Yeah, what the hell is up with brake fluid anyway? That stuff tastes worse than gasoline.
Darrin
Darrin is offline
post #11 of 19 (permalink) Old 02-10-2007, 09:56 AM
Sig Nazi & Gallery Moderator
mrs.tbirdbrain's Avatar
Noooooooooooow I understand why you guys are like you are
TBIRDBRAIN - PRESTON
YOU WILL NEVER BE FORGOTTEN
4/22/63 - 4/23/14
RIP JOEL BENDER
07/30/1979 - 03/26/2006
mrs.tbirdbrain is offline
post #12 of 19 (permalink) Old 02-10-2007, 10:07 AM
It is nice
freon taste damn good plus you can get high off the fumes although a nice glass of mercon5 in a wine glass is nice.
91CougarLS is offline
post #13 of 19 (permalink) Old 02-10-2007, 10:52 AM
VicRattlehead's Avatar
i prefer some 5w30 with some metalic flake in it. yummy
CMP Drag Racing
VicRattlehead is offline
post #14 of 19 (permalink) Old 02-10-2007, 11:12 AM
And Seafoam keeps you regular.
Jay
post #15 of 19 (permalink) Old 02-10-2007, 12:23 PM
Darrin
Especially when someone finds your snapple iced tea bottle in the garbage and figures it would be good for holding some dirty old brake fluid, then you see your iced tea sitting on the bench and take a big swig of it only to find out that the light brown liquid in the iced tea bottle isn't iced tea at all. That happened to me a few weeks ago, and it seriously took the entire day and 2 packs of gum to get the taste out of my mouth.
post #16 of 19 (permalink) Old 02-10-2007, 12:55 PM
Brake fluid is OK, but you have to dip your cigarete in it then smoke!
post #17 of 19 (permalink) Old 02-10-2007, 07:31 PM
Just dont get Brake Fluid in your eye! It burns like hell!
No DON'T ask me how I know!
http://images19.fotki.com/v358/photo...Tbird01-vi.jpg
1994 White (WT) TBird - 4.6 L SOHC with 4R70W
"Sir, if you were my husband, I would poison your drink."
-Lady Astor to Winston Churchill
"Madam, if you were my wife, I would drink it."
-His reply
Rehab progress link
Today's Progress
DScruggs is offline
post #18 of 19 (permalink) Old 02-10-2007, 10:28 PM
Not as bad as battery acid
post #19 of 19 (permalink) Old 02-11-2007, 12:05 AM
As for brake fluid and battery acid in the eye, I've had both. Neither are pleasant. However, the worst was when I put the seat back in my F150 and the corner of the seat slider punctured a can of bear spray. It's pepper spray like what ladies use for protection but specially formulated for grizzly bears. Holy crap that stuff was nasty! If someone was beating the crap outta me, I don't know that I would use that stuff against him just because of how terribly horridly nasty that stuff is. On the subject of tractor hydraulic fluid, I'm all for it. The guys on the turbomustangs forum have used the John Deere HyGard fluid with great results. Gear shifts are snappier and it helps keep the clutches/bands from burning up. It would seem that at least that particular hydraulic fluid is substantially less slick than Dexron III.
ScottJackson is offline
