tranny crossmember - TCCoA Forums
post #1 of 6 (permalink) Old 02-09-2007, 10:38 PM Thread Starter
tranny crossmember
I need to change my transmission crossmember and I want to know if I can swap it without removing any of the exhaust pipes.
red and proud is offline
post #2 of 6 (permalink) Old 02-10-2007, 12:58 AM
Traveler's Avatar
Well, I don't know if you can or not. But when I pulled the crossmember to put new bushings in it, I tried every way I could to do it without dropping the exhaust pipes and couldn't do it. Drop the pipes, its much much easier.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 6 (permalink) Old 02-10-2007, 11:35 AM Thread Starter
any helpful advice on dropping the pipes? I have a fear of snapping bolts where the pipe joins the manifold.
post #4 of 6 (permalink) Old 02-10-2007, 11:41 AM
Whining Intakes Rock
Al_Florida's Avatar
Use PB Blaster at least a few hours before you try to loosen them. A couple of shots the night before would be good.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #5 of 6 (permalink) Old 02-10-2007, 01:18 PM
Traveler's Avatar
LOL Well, I cut them in the straight area between the cats and the crossmember. Dropped the entire exhaust setup, then used clamps to reconnect them.
http://www.imperialinc.com/items.asp?item=0717760
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 6 (permalink) Old 02-11-2007, 02:53 AM
You don't NEED to remove the exhaust but it will make it easier. What you can try to do is have a jack under the trans and then unbolt the crossmember from the trans mount and the frame. Then slowly lower the jack until you reach a point where you can maneuver the crossmember out. You might even have to remove the trans mount from the trans if you can't get the stud out of the crossmember. If you do do this, just make sure to pay attention to the exhaust so it doesn't break when you are lowering it.
And with this post, I am officially a whore. Keg party!!!
