Transmission issues: 97 Ford Explorer 5.0L AWD - TCCoA Forums
post #1 of 5 (permalink) Old 02-10-2007, 05:44 PM Thread Starter
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
Exclamation Transmission issues: 97 Ford Explorer 5.0L AWD
Ok, here's the deal. The transmission in my mom's explorer started acting up today. From a stop it slips badly, hardly moving. Once it starts moving, it still slips a little bit, but not much. I was able to drive it home. I checked the fluid, and it was low, so I filled it up with the same result in driving it. I'm assuming that it is dead as a doornail, but wanted to make sure there isn't anything I should check before I spend my mom's money on another transmission that they can't really afford right now.
Also, would there be any benefit to replacing the stock tranny with one out of a 99+ like there would be for our cars? And would the electronics need to be altered (repinned, etc.) like our cars to use a newer one in the explorer? Has anyone does anything similar before? Wiring diagrams?
Please respond quickly, because I can't afford to have any down time with this. I'll probably start taking the old tranny out tomorrow and get a low mileage used one on Monday when the yards open to put back in it.
Thank you in advance,
Rob Hammerling
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
[email protected], 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
post #2 of 5 (permalink) Old 02-10-2007, 06:11 PM
motor city poster
Red96Bird's Avatar
one thing that makes the car feel like this is happening, is a dirty MAF, basically remove the two torx bolts, spray with maf cleaner or brakekleen, let dry, and re-install, takes 10 minutes...
you just need a tamper proof 20 torx bit,
i once thought my trans was crap, but all it was was a dirty Mass air flow sensor.
try cleaning that and see if it takes care of it.
Red96Bird is offline
post #3 of 5 (permalink) Old 02-10-2007, 06:24 PM
I'm not far from you if you want to bring it over I can fix it. I'm sure that will reduce downtime.
post #4 of 5 (permalink) Old 02-10-2007, 06:36 PM Thread Starter
I sent you a PM.
Rob
post #5 of 5 (permalink) Old 02-17-2007, 08:37 AM Thread Starter
I wanted to thank both dirtyd0g and Darrin for helping me out, even though I didn't buy a rebuild from them (though if it were in the repair budget, I would have, they definitely offered the best price). I got it all back together on Wednesday night.
I bought a used 2000 Explorer tranny with 34K on it for $475 and no core. I repinned the wiring harness (Alan informed me that this also worked on the SUVs; I wasn't sure) and it works great, contrary to what the resident transmission guru on explorerforum had said. He thought I would have to swap out the solenoids and whatnot to the older style in order for the PCM to control it. I'm glad he was incorrect.
Thanks again,
Rob
