b&m shift kit for an 91 5.0aod - TCCoA Forums
post #1 of 4 (permalink) Old 02-13-2007, 10:18 PM Thread Starter
i just picked up a supposed good condition aod out of another 91 5.0 and am going to refresh it a little before i throw it in my car. Im looking into a shift kit as i hear they can extend the life of a trans with the help of a trans cooler which i am also picking up. I work at advance auto and can get this shift kit for $30
http://www.partsamerica.com/ProductD...pe=651&ptset=A
does anybody have any experience with it? the only other one ive seen discussed is the transgo kit.
5.0_Mo is offline
post #2 of 4 (permalink) Old 02-14-2007, 12:32 PM Thread Starter
anybody?
5.0_Mo is offline
post #3 of 4 (permalink) Old 02-14-2007, 01:39 PM
Stevo1111's Avatar
Send a message via AIM to Stevo1111
The B&M kit seems to be more race oriented. My friend has one in a 5.0 Mustang AOD and it snaps your neck on every shift, even if you're going 10mph 1-2. I've heard very good things about the Baummann electronic controlls AOD recalibration kit. Google it. Transgo also makes a shift kit for these cars that many people use with good results.
1991 Thunderbird 5.0:
Cobra upper and lower intake, 65mm Ford Racing TB, E303 cam, opened up E7 heads, Mac headers, Magnaflow true Duals, Tragnsgo shift kit, 3.73's in an auburn posi, hardly spins the tires! I NEED MORE SPEED! Anyone have anything quicker they want to trade for? PM ME!
http://s141.photobucket.com/albums/r...1165080039.pbw
Stevo1111 is offline
post #4 of 4 (permalink) Old 02-14-2007, 08:45 PM
dwinthrup's Avatar
I had the b&m shift kit and hated it. at first i liked it but i broke in 2 days. when it worked it shifted so hard you could feel it in you back and floored it barked the tires. then it just went away I've heard nothing but bad things about b&m shift kits. I would just 5spd it
dwinthrup is offline
