Gears what to get? - TCCoA Forums
post #1 of 37 (permalink) Old 02-18-2007, 07:04 PM Thread Starter
Tim
Tim's Avatar
Gears what to get?
I'm looking to get rear end gears and i cant decide what to get my car is pretty much stock 96 lx. So if you guys could tell me what you guys think that would be great on helping me decide on what to get. I wanted 410s but i drive the car on a regular basis so if you could tell me what gas mileage you get to with them to that would be great. thanks!
Tim is offline
post #2 of 37 (permalink) Old 02-18-2007, 07:14 PM
JustinH's Avatar
I have 373's with a 4000rpm stall, its fine around town and fine on the highway.
I wouldn't go steeper than 373 if you are concerned about gas mileage, you just run out of gear too fast.
JustinH is offline
post #3 of 37 (permalink) Old 02-18-2007, 07:23 PM
coggonobrien's Avatar
i run 4.11's and get around 20 with my v8 on the highway (i'm running a 28 tall tire too so that prolly brings the ratio down to 3.93)
coggonobrien is offline
post #4 of 37 (permalink) Old 02-19-2007, 01:46 AM Thread Starter
Tim
Tim's Avatar
My buddy said if i cant decide that i should go with 390s, does anybody have those in there car?
Tim is offline
post #5 of 37 (permalink) Old 02-19-2007, 10:49 AM
Silenced's Avatar
What are your plans for this car? There is a lot more than gas mileage to consider.
A few things I would look into:
What RPMs are you going to spin the engine?
Will you be taking this car to the track?
What is your powerband going to look like?
Silenced is offline
post #6 of 37 (permalink) Old 02-19-2007, 11:11 AM
Toombs's Avatar
Don't forget about your driveshaft. Factory limiter @ 105mph with 3.27's, so with 4.10's, the same driveshaft speed happens at 84mph!!
With my 4.56's, it's only 75mph, so I got a new shaft made to take the higher RPM.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- DirtyDog Converter (3,800)
- SCT Micro Tuner from Blue Oval Chips
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #7 of 37 (permalink) Old 02-19-2007, 11:19 AM
tbirdtess's Avatar
3.90's
Hello
Well I have 3.90's in my car. However it is a Oval track Car. No street driving.
3.90's are quite obscure. I got mine from Motive Gear for 8.8's only!
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #8 of 37 (permalink) Old 02-19-2007, 08:23 PM Thread Starter
Tim
Tim's Avatar
Want to use it for the street and strip. Engine is stock so its not going past 5500 rpm.
Tim is offline
post #9 of 37 (permalink) Old 02-19-2007, 08:24 PM Thread Starter
Tim
Tim's Avatar
Originally Posted by tbirdtess View Post
Hello
Paul
Do you think they would be a good for street use?
Tim is offline
post #10 of 37 (permalink) Old 02-20-2007, 11:15 AM
Silenced's Avatar
My theory on these cars is if you are ever going to 6000 rpms or greater at the track, look for 4.10s (Or more if you rev higher). Otherwise 3.73s would probly be your best bet.
I hope to have a forged motor eventually that can rev (and hopefully make power) past 6000rpms. At 6000rpms, I should be hitting the rev limiter at 125 with 4.10s and the stock tire size. I don't forsee myself trapping higher than 125mph.
Just remember, these transmissions can't do 3-4 shifts under WOT.
Btw, Thaks to DirtyD0g for building my differential! Its been too cold to do the install
Silenced is offline
post #11 of 37 (permalink) Old 02-20-2007, 11:20 AM
The Great Obucina's Avatar
3.73s would be just fine for a daily driven car that sees highway use.
"Booyah". Stu Scott.
The Great Obucina is offline
post #12 of 37 (permalink) Old 02-20-2007, 11:55 AM
I had 3.73's in my 94 and drove it 110 miles every day! My opinion is that anything over 3.73 is just too high for the street (steet = 70 - 80 mph on the interstate).
I think you will be very happy with 3.73's. But that's just my opinion.
69 F100 LWB w/460 Engine
post #13 of 37 (permalink) Old 02-20-2007, 12:27 PM
Dusty's Avatar
I now have 3.73 in my 4.6 TBird and I like them just fine for all types of driving. I had 3.08, and went to a 3.27 track lock and now have 3.73 track lock in an aluminum pumpkin. I also got a MMX driveshaft when I got the 3.73. I actually see no difference running 70-85 between the 3.27 and 3.73 other than the tach is a little higher. I just went on a trip to Atlanta and went 70-85 until I got to town. The tach was in the 2700 rpm range and it was smooth as glass. I am sure you pay some gas mileage penalty, but it is not much unless you are like 94DD and have a big commute and then every little bit helps. I have also done some 100+ cruising and again very smooth, but not sure if it would be the same with a stock driveshaft. A lot depends on tastes and how you drive the car, but the 4.6 seems to like the rpms.
Dusty is offline
post #14 of 37 (permalink) Old 02-20-2007, 12:49 PM
I have 4.10's trac-loc in an alum. case ..I love the launches and response the car has now...highway mileage isn't god awful terrible, but I still have my 3.27's in an iron case..so if i go on a road trip I can have my mileage back in a 45min. swap.
Justin McC
Stinkfist04 is offline
post #15 of 37 (permalink) Old 02-20-2007, 01:17 PM Thread Starter
Tim
Tim's Avatar
So is there a big difference between 373 and 411s? because if i'm going to get the same response off the line i would probaly go with 373s.
Tim is offline
post #16 of 37 (permalink) Old 02-20-2007, 02:39 PM
Toombs's Avatar
There's about a 10% increase in torque to the ground with 4.10's over 3.73's. There is an associated 10% increase in RPM for a given speed. On the freeway, that means you'll go from about 2000 RPM at 70 mph with stock 3.27's, to about 2300 at 70 mph with 3.73's, to about 2550 at 70 mph with 4.10's. With my 4.56's, 70 mph means about 2800 RPM.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #17 of 37 (permalink) Old 02-20-2007, 05:09 PM
vegeta1181's Avatar
I have 3.73's in my 95 and I'm really happy with them over the stock 3.08 gears. I think 4.10's would be a little steep for me. Mainly because I do plenty of highway driving and don't want to sacrifice MPG. I'm planning to get 4.10's for my Mach 1 though.
2017 Ford Fusion Sport
1995 Tbird LX: 305 Big Bore DOHC Mach I Engine: SOLD
vegeta1181 is offline
post #18 of 37 (permalink) Old 02-25-2007, 11:13 AM Thread Starter
Tim
Tim's Avatar
I dont want to start another thread but is the mark 8 aluminum drive shaft better than the stocker on my 96? I have a chance to get one.
Tim is offline
post #19 of 37 (permalink) Old 02-25-2007, 01:18 PM
only the 93 mk8 driveshaft is any good.
post #20 of 37 (permalink) Old 02-25-2007, 01:29 PM Thread Starter
Tim
Tim's Avatar
Is it balanced enuff to go past 105?
Tim is offline
post #21 of 37 (permalink) Old 02-25-2007, 01:33 PM
since it is now a 14 year old piece.....i would doubt it now, but a shop could balance and index it for you.
post #22 of 37 (permalink) Old 02-25-2007, 02:13 PM
Banned
honestly i had 3.73's and now that i think about it 4.10's would be better but would affect gas mileage. That is why next time around im going 3.90's....its inbetween the 3.73s i had compared to 4.10's...i think 3.90's would be great for a street/strip car....
Porkchop is offline
post #23 of 37 (permalink) Old 02-25-2007, 05:27 PM
VicRattlehead's Avatar
id go 4.30 or 4.56
and you cant get a 4.11 for a 8.8
CMP Drag Racing
VicRattlehead is offline
post #24 of 37 (permalink) Old 02-25-2007, 05:29 PM
Banned
i think its funny that people with 3.73's say go for 4.10s and people with 4.10's say to get 4.30's lol
Porkchop is offline
post #25 of 37 (permalink) Old 02-25-2007, 05:34 PM
Chapter Director Coordinator
jamesD's Avatar
3.90 would be a moderate balance between the two.. but hard to find "cheap"
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #26 of 37 (permalink) Old 02-25-2007, 05:37 PM
Banned
how abut 170 shipped new?
i really want 3.90's but if i can get 4.10's for cheap enough *new* i will go that route...
Porkchop is offline
post #27 of 37 (permalink) Old 02-25-2007, 05:44 PM
jamesD's Avatar
175 not cheap.. and i wouldn't trust ebay on stuff like that
jamesD is offline
post #28 of 37 (permalink) Old 02-25-2007, 05:45 PM
Banned
well seeing how jason sells them for that price too i dont think thats too bad..
Porkchop is offline
post #29 of 37 (permalink) Old 02-26-2007, 03:45 PM
can 3.73 be dropped in a car without doing anything to the ecu (burned chip) , and just changing the speedo gear? I remember something about the computer only being able to go 2 gear steps either way or something? stock 3.08 here
mike884_2 is offline
post #30 of 37 (permalink) Old 02-26-2007, 03:50 PM
Banned
3.08 isnt 2 steps away from 3.73's
it goes 3.08, 3.27, 3.55, 3.73, 3.90. 4.10....etc
i went from 3.27's to 3.73's with a tune but for about a week i didnt use the tune and the stock ecu tuning did alright with the 3.73's....the shift points were a lil weird sometimes but yes with a ecu tner or chip it can fix that.
Porkchop is offline
