HalfShaft and Gear Question? - TCCoA Forums
post #1 of 4 (permalink) Old 02-25-2007, 07:51 PM Thread Starter
Alright, i have the 3.8, but i have an 8.8 rear end with 3.08 gears. Now would the 8.8 automatically come with bigger halfshafts , despite the fact it is a v6, and are those the same size as v8/sc ? Secondly, I heard that for gear swaps you can move two steps up or down and the computer can handle that difference? So I could swap in 3.55 gears, and not need to burn a chip or anything correct? Also anyone change the 3.08 to 3.27, how much difference that makes, or 3.08 to 3.55, just to hear someones opinion rather than numbers and rpms and what not
mike884_2 is offline
post #2 of 4 (permalink) Old 02-26-2007, 01:04 PM
wether's Avatar
The Left Side (Driver's Side) half shaft of the SC's is bigger/more sturdy than all the rest. This is the only difference in MN12 half shaft sizes.
The answer to your gearing/speedo question is yes and no. Yes, you can change the gearing without a chip reburn but you have to change the speedo gear on the speedo sensor on the extension housing of the tranny. It is fairly easy to do since the gear is heald on the sensor by a small snap ring type clip. The different gears could be purchased from Lonnie at http://www.blueovalchips.com.
To go from 3.08 to 3.55 gears would be a noticable difference, but I am not sure it would be worth the money. . . .that is to say that I don't think it is "that" noticable a difference. Combine it with a good torque converty from dirtyd0g and it will definately be highly noticable, but now you've spend at least $200.
JMO
wether is offline
post #3 of 4 (permalink) Old 02-26-2007, 02:27 PM Thread Starter
can you make the leap to 3.73 without messing with the ecu and just changing the speedo gears, or would that require a reburn. Also what type of converter from dirtydog would you suggest, the car will probably never even hit 200 hp , so it dosent have to be extreme by any means
post #4 of 4 (permalink) Old 02-26-2007, 03:32 PM
wether's Avatar
There is currently a Group Purchase going on for torque converters by dirtyd0g: http://forums.tccoa.com/showthread.php?t=93440
You can call Alan (dirtyd0g) to discuss what he thinks is best (stall wise). I would figure that the basic stock rebuild with a slightly higher stall (2400 - 2500) would be right up your alley for the "fun" aspect. If you contact Alan, he can probably set you up with a nice deal to do the torque converter and rear end at the same time. He does build quality torque convertors and rear ends. . . . .he is also in Batavia, OH. So, judging by your profile it is only about 4 hours away (if I remember the time from Cleveland to Cinci).
Let me know if there are any other questions. . . . .
If I remember correctly you can go to 3.73's by just changing the gear on the speedo sensor, but there is a problem with this gear (on the sensor) being eaten by the tranny because of the size of the gear's teeth. I was reading threads about it somewhere around here. I have only ever riden in a car with 3.73's once and it was really nice off the line, but it was a standard, so that has something to do with it also.
wether is offline
