ford t56 bellhousing on chevy t56? - TCCoA Forums
post #1 of 7 (permalink) Old 02-25-2007, 08:54 PM Thread Starter
does anyone know if the ford t56 bellhousing will bolt onto the chevy t56? im curious to find out weather i absolutly need that mcleod bellhouseing or not, there kinda pricey, and factory bellhousings are a dime a dozen on ebay.
jemorganiii is offline
post #2 of 7 (permalink) Old 02-25-2007, 09:24 PM
i'm pretty sure it will
post #3 of 7 (permalink) Old 02-25-2007, 09:35 PM
coggonobrien's Avatar
Talk to tremec then share the wealth of info
coggonobrien is offline
post #4 of 7 (permalink) Old 02-26-2007, 01:02 AM
MarksM's Avatar
Send a message via AIM to MarksM
No, the front plate on the trans is different. Just get the McCleod modular bellhousing.
2007 Buell XB9S
MarksM is offline
post #5 of 7 (permalink) Old 02-26-2007, 03:27 AM
4.6
ls1
the bolt holes all look like they're in the same locations, except for the missing hole on the gm one above the clutch fork area
post #6 of 7 (permalink) Old 02-26-2007, 08:37 PM
MarksM's Avatar
You can try it. I just examined the rebuild documentation and it shows different front plates as well as bell housings for the GM, Ford, Dodge and aftermarket renditions. The GM front plate is machined for the GM spec input shaft, Ford for Ford, etc.
2007 Buell XB9S
MarksM is offline
post #7 of 7 (permalink) Old 02-27-2007, 12:29 AM Thread Starter
i have talked to tremec about swaping tailshafts and the gentelman i spoke with said that the t56 was designed essentially as a modular transmission. the gto t56 is just a ls1 t56 with a different tailshaft, alot of the parts are interchangeable between different model years and manufaturers. they are just kinda hard to get ahold of a good tech guy at tremec, they all seem to wanna pass your call off to the next joe..
