MLPS Help - TCCoA Forums
post #1 of 7 (permalink) Old 02-26-2007, 08:58 PM Thread Starter
OTOWNBIRD's Avatar
MLPS Help
I just took off my old mlp and the center piece was loose so there is no way to match the old to the new. Is there a way to line it up correctly?
Long story short, I just completed the engine swap, the car has been sitting for about 4 months, no prior tranny problems. Now the new motor is in and the car hesitates to shift to 3 and 4. When the engine was out I did replace the fluid in the tranny and tc?
Your ego is writing checks your a$$ can't cash.
Installing a motor with some parts to go faster.
Oh yeah the engine is painted so that adds 15hp right there!
OTOWNBIRD is offline
post #2 of 7 (permalink) Old 02-26-2007, 09:01 PM
Banned
put your shifter in the neutral position. then look at the mlps and set the inner circle to the "neutral" position. You will see a tick mark and turn it into that position. Slide it onto the lil shaft and bolt it down.
Piece of cake...
Check your fluid levels for the hesitate...
Porkchop is offline
post #3 of 7 (permalink) Old 02-26-2007, 09:03 PM Thread Starter
OTOWNBIRD's Avatar
Ok. so line the 2 notches up with the line that says neutral and bolt back down?
post #4 of 7 (permalink) Old 02-26-2007, 09:04 PM
Banned
Yes turn the notch on the mlps to the "neutral" position and slide it in and blt down while your shifter is in the neutral position
Porkchop is offline
post #5 of 7 (permalink) Old 02-26-2007, 09:06 PM Thread Starter
OTOWNBIRD's Avatar
Thanks for you help. I will keep you posted!
post #6 of 7 (permalink) Old 02-26-2007, 09:33 PM Thread Starter
OTOWNBIRD's Avatar
Ok followed your advice to a T...Car is in neutral and I lined up the sensor. BUT..When you put the sensor on it requires the notches to turn a little in order to fit back on .. Is this normal...
post #7 of 7 (permalink) Old 02-26-2007, 09:59 PM
Banned
sure....put it on and plug it in. then start the car and test its operation.
Porkchop is offline
