01 mustang tranny swap.... - TCCoA Forums
post #1 of 7 (permalink) Old 02-28-2007, 11:16 AM Thread Starter
fl96thunderbird's Avatar
Send a message via Yahoo to fl96thunderbird
Okay almost done with the swap but I have come across a little problem. I don't remember seeing this posted on any swap questions, but I have a bad memory.
The way the gear selecter cable connects to the tbird tranny and mustang tranny are different. How have you other swappers corrected this? Thanks
fl96thunderbird is offline
post #2 of 7 (permalink) Old 02-28-2007, 11:38 AM
Eleventeenth Gear Poster
Aaron K.'s Avatar
I think you have to use the Tbirds MLPS, the the Mustangs.
Sold = 96 Thunderbird
Aaron K. is offline
post #3 of 7 (permalink) Old 02-28-2007, 11:42 AM
Darrin's Avatar
Yes, you need to swap the manual lever into the transmission that is correct for your car.
Darrin
Darrin is offline
post #4 of 7 (permalink) Old 02-28-2007, 11:48 AM Thread Starter
I thought it was just the sensor that had to be swapped over, not the whole piece going into the tranny. Okay, thanks
post #5 of 7 (permalink) Old 02-28-2007, 11:54 AM
For some reason on my GT tranny it now locks the shifter into place in 2nd gear instead of Drive. Not sure how to fix this. It now just slips into N without having to push the button. Anyone else have this issue with this?
94ONAIR is offline
post #6 of 7 (permalink) Old 03-07-2007, 02:26 PM Thread Starter
Finally got a hold of a scanner...
P1747- control solenoid short
P0755- shift solenoid b
P0750- shift soleniod a
P0743- tcc electrical fault
P0712- tft sensor low input
All of these make me think its the wrong repinning of the bulkhead....I double checked the diagram against my car and all seems well...reopened the pan to check the connections and everything seems okay there too. Anything else to look for/at? If not I'mm gonna have to swap over all the electronics from my 96 tranny.
Oh and yes I moved the tcc mlps vss oss over.
post #7 of 7 (permalink) Old 03-07-2007, 03:56 PM
02 Explorer Pioneer
timb's Avatar
I used the Tbird MLPS and modified the cable and bracket to mount to the mustang lever
Birdless
timb is offline
