how do i knwo if i have traclock or not - TCCoA Forums
post #1 of 27 (permalink) Old 03-01-2007, 07:40 PM Thread Starter
i have a 95 t-bird and i whave a set of 4.10s and everything to put them in but idk if my car has the trac.loc or posi or whatever you want you call it.. how can i find out
EHat911 is offline
post #2 of 27 (permalink) Old 03-01-2007, 07:41 PM
95xbird's Avatar
I doubt you have T-lok.You can check the door jam for the axel code.My car came with 3.27's which I hear is rare for an LX.Maybe not but most I see come with 3.08 open diff.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #3 of 27 (permalink) Old 03-01-2007, 07:42 PM
miller1995's Avatar
Check your door code:
http://www.tccoa.com/articles/gears/gears.html
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #4 of 27 (permalink) Old 03-01-2007, 07:49 PM Thread Starter
if i dont how can i go about getting a posi rearend for this car what would i need to get it out of
EHat911 is offline
post #5 of 27 (permalink) Old 03-01-2007, 08:22 PM
Resident drifter
slidebird91's Avatar
I believe most 96/97 v8 t-birds had it. correct me if I am wrong. do a burnout (legally). do both wheels spin?
slidebird91 is offline
post #6 of 27 (permalink) Old 03-01-2007, 08:24 PM
coggonobrien's Avatar
power brake the s.o.b. and see if both tires light em up
coggonobrien is offline
post #7 of 27 (permalink) Old 03-01-2007, 08:45 PM Thread Starter
i have a 95 but see thats the problem sometimes they do and sometimes they dont. i guess it depends on how hard i hit the gas. because with foot on brake if i just mash the car both with spin but if i just kinda push on it one the passenger one does
EHat911 is offline
post #8 of 27 (permalink) Old 03-01-2007, 08:52 PM
Who is John Galt?
Not necessarily. If you want a locking rear, print out the page that Miller linked to and hit the yards. If not, you're looking at some $$ to have one built.
"Won't work, can't be done"
cougar_guy04 is offline
post #9 of 27 (permalink) Old 03-01-2007, 09:00 PM Thread Starter
i know it sounds stupid but which ones on that chart actually have a locking rear end in it , if im write it's the ones with 2 letter/numbers under the AX right
EHat911 is offline
post #10 of 27 (permalink) Old 03-01-2007, 09:02 PM
Who is John Galt?
What do you mean? Which cars? With the cars it's a crap-shoot. I think there were certain SC's that were more likely to have locking rears, but someone else could shed some more light on that.
post #11 of 27 (permalink) Old 03-01-2007, 09:06 PM
miller1995's Avatar
In that link I posted there are two colums. The codes under conventional are for open rears and the ones under lock are the limited slip codes. The third column lists the ratio that those codes are for. When looking at a diff there will be a tag on one of the cover bolts. This tag has a bunch of numbers but the most important is the ratio which as an example a 3.27 ratio rear will be 3 27 for an open and 3L27 for a locking rear.
-Miller
SOLD1998 Escort ZX2
post #12 of 27 (permalink) Old 03-01-2007, 09:10 PM Thread Starter
ohhhhh i get it now sorry im alittle slow you will all soon learn that haha
EHat911 is offline
post #13 of 27 (permalink) Old 03-02-2007, 04:45 AM
Icarus's Avatar
Put the rear end of the car in the air with the wheels free (jack stands), put it in neutral and spin one of the tires with your hand. If the other tire spins the same way, you have a trac loc... if it doesn't, its an open diff.
...or pop the cover off the diff and look for a big S spring right in the middle of everything...
Ϣr
1994 Lincoln Mark VIII
4.6L DOHC; meter4it.com chase/sequential tail lights; 20" Giovanna Dalars; 4.30 gears; FRPP Track-Lok; SCT tuned; Baumann ReCal; Addco bars; Cobra brakes...
RIP - '86 Mark VII LSC
Icarus is offline
post #14 of 27 (permalink) Old 03-02-2007, 05:40 AM
Banned
another way to test to see if you have trac-lok is to go to the beach and put one tire in the sand and the other on pavement. floor it...if you get stuck and move very slowly then you dont have trac-lok. if both tires spin fast and you get un-stuck then you have trac-lok
That, or you can do it the easy way and check the door jam sticker where it lists the body color code/vin number/etc. Like stated above look for the letter/number under where it says "AX".....then click on the link above and see where your code falls into.
Porkchop is offline
post #15 of 27 (permalink) Old 03-02-2007, 04:40 PM Thread Starter
yeah i looked at the sticker this morning and it was a Y so no i dont have trac loc
boo now i have to spend more money
EHat911 is offline
post #16 of 27 (permalink) Old 03-02-2007, 04:58 PM
Resident drifter
ha, I forgot about that way. It is the easiest.
post #17 of 27 (permalink) Old 03-02-2007, 08:00 PM
Traveler's Avatar
Nah, checking the code is the easiest. But that beach thing sounded like the most fun.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #18 of 27 (permalink) Old 03-02-2007, 10:07 PM
jack up the rear so that one tire is on the ground and the other isn't and try to turn the wheel
sleepinggt is offline
post #19 of 27 (permalink) Old 03-03-2007, 03:08 AM
Banned
Porkchop is offline
post #20 of 27 (permalink) Old 03-03-2007, 04:55 AM
Icarus's Avatar
EDIT: still won't work on a worn out unit...
I'd agree the stickers the easiest way too, the beach the most fun way, and my way, well... good if you don't have a beach around or the sticker lol... just figured I'd throw it in here...
Icarus is offline
post #21 of 27 (permalink) Old 03-03-2007, 10:21 AM
i searched tracloc stuff on here for a couple weeks, and i was led to believe that it was only like 20 ft lb to break it free.
But I could have been misinformed during my searches.
Anyone know for sure the answer?
red and proud is offline
post #22 of 27 (permalink) Old 03-03-2007, 12:07 PM Thread Starter
Has anyone used this Auburn limited slip diff yet because i was just thinking about using this instead of searching for one from the bone yard adn then having to have it rebuild and all that stuff
http://supercoupeperformance.com/par...px?category=27
EHat911 is offline
post #23 of 27 (permalink) Old 03-03-2007, 01:11 PM
Do you really want to spend $400 on the t-lock.My 94 lx has 3.27 rear end with t-lock,it has 73K miles and whole in the block,so I'm gonna part the car out soon.
Burbank 95sc is offline
post #24 of 27 (permalink) Old 03-03-2007, 06:22 PM Thread Starter
how soon are we talking and how much would you want for it
EHat911 is offline
post #25 of 27 (permalink) Old 03-03-2007, 07:55 PM
Icarus's Avatar
Your right, minimum is 20lb-ft... I misread it from the manual... I was going on no sleep before, sorry
A Traction-Lok differential can be checked for proper operation without removing the differential from the axle housing.
Raise one rear wheel and remove the wheelcover. Install Traction-Lok Torque Tool T59L-4204-A on the axle shaft flange studs.
Using a torque wrench of at least 271 N-m (200 lb-ft) capacity, rotate the axle shaft. Be sure that the engine is not running, the transmission is in NEUTRAL, one rear wheel is on the floor, and the other rear wheel is raised off the floor. The breakaway torque required to start rotation should be at least 27 N-m (20 lb-ft). The initial breakaway torque may be higher than the continuous turning torque, but this is normal. The axle shaft should turn with even pressure throughout the check without slipping or binding. If the torque reading is less than specified, check the differential for proper assembly.
Icarus is offline
post #26 of 27 (permalink) Old 03-03-2007, 09:30 PM
awesome, that is what I thought I read somewhere
post #27 of 27 (permalink) Old 03-03-2007, 09:53 PM
Check your pm box.
