Slight leak from converter access plug? - TCCoA Forums
post #1 of 2 (permalink) Old 03-04-2007, 06:51 PM Thread Starter
I am doing some suspension work so I have the car on stands. I notidsed some dry tranny fluid under the car and traced it to the converter access plug which I removed. Is there something I should/could look for in that hole? The amount n the floor is about 4" in diameter and old and dry. The car is in storage and sometimes some small leaks may appear fom non-use. Another ? is if this is indicitive of a common problem with tranny or converter? Tahnks, mark
PS: I would like to do a J-mod but already have a '99 4R70W and have not seen directions for that year. How long does this mod typically take? I tried to access darrins site but it is shanged and I cannot see his products. I believe he offered 2-3 different valve bodies already modified. Advice/suggestions please? Mark
sweet99 is offline
post #2 of 2 (permalink) Old 03-04-2007, 08:51 PM
Amateur Expert
Embalmer's Avatar
Send a message via AIM to Embalmer
The front pump seal is the only thing that can be leaking in the bellhousing area, unless it's coming from the converter drain plug.
2007 Ford Mustang GT Premium - SOLD March 2014.
2013 Ford Taurus SHO (TUXESHO) Tuxedo Black Bone stock for now.
Embalmer is offline
