speedo gears - TCCoA Forums
post #1 of 13 (permalink) Old 03-06-2007, 12:50 PM Thread Starter
speedo gears
have the 95 8.8 with 3.08's either going to 3.27 or 3.55. the speedo gear for 3.27 is the 19 tooth one i correct? which one do i need for the 3.55's ?
"it WANTS to be fast, and that is all that matters"....
mike884_2 is offline
post #2 of 13 (permalink) Old 04-02-2007, 09:32 PM
Dang! you think someone would have known this one.
'95 LX 4.6L/ '99 mustang front calipers/ '96 t-bird rear calipers/Baumann transmission/BOC chip by Lonnie/ 225.55.16 Yokohama's on Borbet 5 spoke/poly IRS/ Eibach 1.5" drop/ Lincoln pumpkin with 3.55 trac-loc/ Lincoln rear upper and lower control arms/ rebuilding '94 Mark Vlll eng. for swap/ -Edit- Engine rebuild now finished by Panhandle Performance (2-16-07)/ swap on soon - but needing to get P.I. torque converter- MSD window switch for '98 IMRC'S- rebuild current Baumann Trans--etc.
Thundernerd is offline
post #3 of 13 (permalink) Old 04-02-2007, 09:33 PM
Traveler's Avatar
There is a calulator on SCCOA that will tell you what gear you need for a given application.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 13 (permalink) Old 04-02-2007, 09:58 PM
I come up with 19.5 gear teeth with 225/55/16 tires and a 3.55 rear ratio. I guess I'll use the 21 toother.
'Cause my speedometer is off 10 mph now, the purple 21 tooth one ought to get me to a somewhat more accurate speed indication.
Thanks for the Sccoa tip Traveler-- here's the link -->
http://www.sccoa.com/faq/speedgr.html
post #5 of 13 (permalink) Old 04-03-2007, 12:30 AM
Use the 20 tooth orange.
post #6 of 13 (permalink) Old 04-03-2007, 05:05 PM
Thank's dirtyd0g, checking with ford here--(calling)---- they have a 20 tooth gear but it's black. What's the diff. in colors? Said they'll take back the 21 tooth purple one if the black one will fit.
post #7 of 13 (permalink) Old 04-03-2007, 06:20 PM
I have used the black ones as well I think they are for the ranger transmissions but they work fine. I could be backwards, color doesn't matter make sure it's 20 tooth.
post #8 of 13 (permalink) Old 04-03-2007, 06:34 PM
Thanks for your time- will get the 20 tooth.
post #9 of 13 (permalink) Old 04-03-2007, 09:36 PM
Traveler's Avatar
I'm glad you said that. I have one that I ordered, but it was black. I was worried cause I thought it was supposed to be orange as well.
Thanks again for clearing that up.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #10 of 13 (permalink) Old 04-04-2007, 06:04 PM
Just installed the 'black' 20 tooth gear and it works- even though the shaft end of the gear is substantially shorter than the original green OEM gear.
Will check accuracy with Bee-Line not this weekend but next.
Thank you Traveler and dirtyd0g for your help.
P.S.
the tech. article (found under Gears-Speedo Gear Change) on the procedure is accurate. Although it would have been more informative if one of the photos had shown the assy. with the gear attached.
post #11 of 13 (permalink) Old 04-04-2007, 10:09 PM
Does anyone have the part number for this gear?
Mitch
MitchB is offline
post #12 of 13 (permalink) Old 04-05-2007, 04:16 PM
c1dz-17271-a is the part number on my receipt.(Black 20 tooth)
But I believe the gear is for manual trans cars, as dirtyd0g mentioned, due to the shorter shaft.
However, it works quite well in my '95 t-bird, (3.55 with 225/55/16 tires) and appears to be accurate according to my stop watch and mile markers. Will go to Bee line soon for a real accuracy test.
Here's a web site that lists a lot of gears -->
http://www.hardcore50.com/technical_..._and_Gears.htm
post #13 of 13 (permalink) Old 05-02-2007, 12:08 AM Thread Starter
wow didnt know anyone responded to this, so i will get the 20 tooth orange, thanks!
