Pin-out for new transmissions - TCCoA Forums
post #1 of 8 (permalink) Old 03-07-2007, 01:02 AM Thread Starter
96bird's Avatar
I didn't save the pictures from the write up that Frankencougie put on modulardepot.com. Does anyone have them? I will be swapping an '02 GT transmission in soon and want to make sure that I understand what needs to be done re-pinning the connector. Thanks for any help.
Russell
96bird is offline
post #2 of 8 (permalink) Old 03-07-2007, 04:09 AM
fl96thunderbird's Avatar
Send a message via Yahoo to fl96thunderbird
I have a pdf file of a write up on the pinning of the 94-97 4r70w and 98+ 4r70w....but I don't know how to get it to you. I found it, theres another that I cross referenced to be sure and it matched. I am trying to finish a swap from an 01 mustang base.
http://www.personal.psu.edu/tfg112/t...icle/swap1.pdf
Hope that helps. Scroll down and it will show you the two drawings from the different years.
fl96thunderbird is offline
post #3 of 8 (permalink) Old 03-07-2007, 10:36 AM
Dusty's Avatar
Hey Russell,
Take a look at this link: http://www.p71interceptor.com/tranny...ead/index.html
I guess Scott took his pictures down.
Dusty is offline
post #4 of 8 (permalink) Old 03-07-2007, 09:10 PM Thread Starter
96bird's Avatar
Thanks Dusty and fl96thunderbird. So I just need to repin the connector and put my old MLPS and TCC on the new transmission? I just want to make sure I have everything straight before I jump into it.
Russell
96bird is offline
post #5 of 8 (permalink) Old 03-07-2007, 09:26 PM
Dusty's Avatar
That is what I think. You might want to get Darrin's opinion.
Dusty is offline
post #6 of 8 (permalink) Old 03-08-2007, 02:29 AM
Just go over the articles, the whole mlps lever inside the tranny, not just the sensor outside. I thought it was just the piece outside but Darrin informed me of the whole assembly needing to be transferred. Hope you have better luck than I am.
post #7 of 8 (permalink) Old 03-08-2007, 06:55 PM Thread Starter
96bird's Avatar
I have been over the articles but I can do things better when I am under the car looking at the whole thing. I know I have to put my VSS in there as well. I PM'ed Darrin, so hopefully he can clear up anything that needs to be addressed.
Russell
96bird is offline
post #8 of 8 (permalink) Old 03-09-2007, 02:34 AM
If you need better pics, let me know while I have the bird in the air. I can email them to you and you can print them, or I can put them on photobucket and send you a link. I have a 3.8 but I would think parts would like very simular if not alike.
