How to tell IRS side gears from Regular C-Clip ones - TCCoA Forums
post #1 of 9 (permalink) Old 03-10-2007, 01:05 PM Thread Starter
SplitPortBird's Avatar
Like the title says,, I have a Posi from a 99' Cobra sittin in front of me and I want to verify that its a IRS posi.
I have both the compare in the garage but they are burried deep and was curious if someone had a side by side picture. or perhaps I will have to be the first to take pics.
LMK,
Brad
SplitPortBird is offline
post #2 of 9 (permalink) Old 03-10-2007, 01:40 PM
The Great Obucina's Avatar
if you know for a fact its from a 99 Cobra, its a no brainer that its from an IRS.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 9 (permalink) Old 03-10-2007, 02:12 PM Thread Starter
Almost kinda explains why I was askin,, because I'm not 100% sure
post #4 of 9 (permalink) Old 03-12-2007, 11:28 AM
IRs side gears have a groove to allow expansion of the circlips. Solid axle have splines all the way out.
post #5 of 9 (permalink) Old 03-12-2007, 11:56 AM
392Bird's Avatar
Side Gears for IRS:
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #6 of 9 (permalink) Old 03-16-2007, 05:11 PM Thread Starter
WTH is that third pic of?? Is that suppose to a mini spool?
Where are the gear teeth on it?
post #7 of 9 (permalink) Old 03-16-2007, 08:41 PM
dwinthrup's Avatar
thats the gear in question thats what the clutch packs go on
dwinthrup is offline
post #8 of 9 (permalink) Old 03-16-2007, 10:08 PM Thread Starter
Maybe its just the pictures,, but it doesnt look like anything I have
post #9 of 9 (permalink) Old 03-17-2007, 12:25 AM
Sidegear seems awfully small huh? I have to assume it's a 31 spline with a 3/4 pin the sizes changed alot on those.
