WHat else besides gears? - TCCoA Forums
post #1 of 45 (permalink) Old 03-18-2007, 11:54 PM Thread Starter
Ive been looking at gears for sometime now and ive come down to the 3.73s or 4.10s. I want to be able to make the tires squeel when i put my foot into it (The gears alone probably wont do that but i can dream). What else would i need to get besides the gears because ive been looking around and have seen like "basic installation kit for gears" and such and am a little confused. any help appreciated.
mitchellb3 is offline
post #2 of 45 (permalink) Old 03-19-2007, 12:32 AM
greencurse's Avatar
first off you'll need a driveshaft either a 93 Mark VIII Aluminum or a Metal Matrix. Next you will need to have the gears professionally installed as it takes some keen measuring and specialty tools to get them set up right. Next you will want a Marauder or dirtyd0g torque converter to make the most of your gears along with a Mark VIII flexplate and a Jmod. You will also need a chip or tuner to correct you shift points because you have changed them with the gears.
1997 Thunderbird LX, 4.6L, Performance White.
3.27 TL, 300hp J-Mod, Mid-Mount Magnaflow w/2.25" True Duals to 3" Magnaflow 15* Slash Cut Tips, PI Intake,
FR500 Steering Wheel, FRPP Wires, 180* T-Stat, 22C Plugs, Cobra Vert Rears, RSTB, SC "L" Braces. 175k and still flying!
greencurse is offline
post #3 of 45 (permalink) Old 03-19-2007, 02:21 AM
Banned
Depends on what you want your car to do. Make it quiker and its for mostly city driving id get 4.10's. If you drive on higher speed roads or freeways most of the time but still want a respectable gain off the line go with 3.73's.
As for the "basic install kit" its just new internal parts for the differential itself such as new bearings/etc. If your gonna put in different gears then you want to rebuild the internals while your there right? For example you dont do an engine swap and not replace your motor mounts or other key parts while your there right?
Hope your differential is a limited slip or "trac-lok" unit cuz putting new gears in a non-traclok equiped diff wouldnt be practical cuz you want that sucker to lockup upon take off but with 4.10's thats gonna make it more difficult. Check your door jam sticker thats near your door on the drivers side. It should contain info such as oem color code/vin #/axle code/and more. Towards the bottom right of the sticker it should say "AX" in one of the categories and look for the code or letter(s) under it. Depending on which code you have you will be able to tell wether you have trac-lok or not. If you dont then look for a trac-lok unit online or at the yards. Your gonna install a new "install" kit for it so doesnt matter if its used or not right?
Along with the basic install kit you will want a trac-lok rebuild kit to replace the old worn shims and clutches. I would recommend having someone who has done this befoe like greencurse said to build up your rear end when you have all the parts ready. Its not something everyone can do so have it profesionaly re-built and installed if you dont know how to remove the rear pumpkin.
Research the j-mod on this forum which is basically a shift kit for our cars to shift quicker and bark the tires. You can order one from lonnie c/o blueovalchips.com and he will set you up with a customized shift kit to your tastes for about $65 + core charge. The kit you get from him will include new springs/filter/acummulators/etc so you can install them into your own valvebody under the transmission. I have seen it done twice now and helped out on one of the times. Cjchevez has done it as well and lives closer to you and might help you out with it provided gas money/food/BEER for him LOL.
If you DO build up your rear end with new gears invest in a new driveshaft seeing how our stock units are heavy and made of steel and are a 2 piece design. Shorter gear ratios will turn the driveshaft at higher speeds and the stock units tend to vibrate or fail. Most of the 1993 Mark 8 vehicles were equiped with one-piece aluminum driveshafts and are a cheap perfect upgrade over our steel ones. You can get them at the junkyard for about 40 bucks and install new u-joints on it and have it re-balanced to handle your new gears.
Lastly invest in a Marauder Torque converter or custom one seeing how they will have a higher stall rating and will allow you to take off the line a lot quicker. Darrin is the man to see about a higher stall torque converter along with j-mod upgrades. Like i said before, it depends on what you want your car to do so let whoever you order parts off of know this so they can help you out. Of course you will need the matching flexplate to go with the converter to bolt up to your tbird like said earlier but dont worry they arent that pricey.
Hope that helps
-Mike
Porkchop is offline
post #4 of 45 (permalink) Old 03-19-2007, 08:07 PM
Silenced's Avatar
I haven't gotten my 4.10s in yet, but I do have Alan's 3800 stall 9.5 converter. I can break the tires loose off the line with:
General XP2000GTs (215x70x15)
Kumho MX (245x35x18)
Toyo Proxies (255x45x18) <-- Just barilly.
Trust me, you don't want to break the tires loose. Its soo much of a pain in the ass to have to ease into it when I want to get off the line.
Powered by:
Megasquirt EMS, Vortech Superchargers, Renegade Racing, Gator1980Transmission, Innovative Motorsports, Devil's Own, Magnaflow, Eibach, KYB, Kooks
Silenced is offline
post #5 of 45 (permalink) Old 03-19-2007, 08:15 PM
Banned
yea wider tires+rain+firm or barking shifts = no fun, well for your passengers at least
Porkchop is offline
post #6 of 45 (permalink) Old 03-19-2007, 09:18 PM
TwoHaggard's Avatar
ha good write ups. so im about to do 4:10s. but dont have money for tuner. so would it be alright to run my car like without one? not tryin to jack your thread.
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #7 of 45 (permalink) Old 03-19-2007, 09:29 PM
Banned
i ran 3.73's without a tune for about a month. your shift points will be off and dont do any wot rus untill you get a tune seeing how you will definatley redline your car most of the time.
when it comes to Wide open throttle take offs our computers calculate when to shift based on mph. if you get gears your rpms will get to redline quicker but the desired mph wont be reached untill you speed up a lil bit.
Safe? yea sure why now just dont blow your motor or your tranny, make sure to manually shift before it gets to redline.
Without a tune thats what happened to my ride and it wouldnt want to shift even at 5500rpm. Trust me our engines sound angry and very bad at 6000rpm lol
edit: try searching for your answers seeing how you are still a noob and asking the same questions i was asking 3 years ago lol. gotSEARCH?
Porkchop is offline
post #8 of 45 (permalink) Old 03-19-2007, 09:39 PM
sCrEaMiN BiRd's Avatar
If i have a 96 4.6L bird does that automatically mean i have an 8.8? I already jacked up the back of my car to check if i had posi, but i didnt. : (. Wheels spun opposite ways... poop. But if i do throw in some 3.73's or 4.10's couldn't i just throw on some drag radials when i go to the track? Since i dont race on the street or anything, i don't really have to worry about the traction problems. Is this a wise decision? Thanks
sCrEaMiN BiRd is offline
post #9 of 45 (permalink) Old 03-19-2007, 09:42 PM
3rd Gear Chirper
hotbird's Avatar
You mean [email protected], or bad as in it's gonna blow? I revved my old one to 6500 and it sounded mean as heck, almost like the Cobra down the street from my parents house except for the fact that he has Flows and I have straight pipes.
Now I have to say it's not a good idea to rev to 6500 on a stock engine, I did it knowing full well what the consequences might be.
**Back on topic**
I ran 4.10's w/o a tune for a while, and most of the time with my jmod it would shift before hitting the rev limiter, sometimes it would bounce once maybe twice and then shift, but your speedo will be off until you get a SpeedCal. If you get 4.10's please don't use the white speedo gear to fix it, the teeth come apart inside the trans, and the trans "filter" is useless due to the location of the gear.
hotbird is offline
post #10 of 45 (permalink) Old 03-19-2007, 09:45 PM
Banned
opposite ways? that means you have limited slip does it not? look at your door jam label. It should tell you info such as paint code/axle ratio/vin#/etc.....look where it says "AX" (like i said above ) and check to see what code you have. depending on the code that you have you will be able to tell which rear end setup you have.
slicks will help with traction but it might not 100% lockup both tires.
Porkchop is offline
post #11 of 45 (permalink) Old 03-19-2007, 10:01 PM
Silenced's Avatar
I have 4.10s now. I haven't installed them yet though. What would you suggest I do as of recalibrating my spedo?
Powered by:
Silenced is offline
post #12 of 45 (permalink) Old 03-19-2007, 10:15 PM
Banned
seriously? do you know what search is?
use the right tranny speedo gear with the right gear setup
Porkchop is offline
post #13 of 45 (permalink) Old 03-19-2007, 10:20 PM
My 06 GT i know for sure has a posi and it spins the same direction.
post #14 of 45 (permalink) Old 03-19-2007, 10:21 PM
Banned
mine was posi and while on jackstands they turned different directions
Porkchop is offline
post #15 of 45 (permalink) Old 03-19-2007, 10:24 PM
My door says 5 under axle.
post #16 of 45 (permalink) Old 03-19-2007, 10:25 PM
really? All my friends cars with traction lock, posi, etc. all spin the same way. Maybe your posi is worn out or something? Or am i crazy here. Dont make me jack up my mustang just to see if i'm crazy or not... : (
post #17 of 45 (permalink) Old 03-19-2007, 10:25 PM
Posi? you had a GM differential?
post #18 of 45 (permalink) Old 03-19-2007, 10:26 PM
Oops i made that mistake also. Is the correct term traction lock?
post #19 of 45 (permalink) Old 03-19-2007, 10:28 PM
Banned
you know what i mean!! lol
Porkchop is offline
post #20 of 45 (permalink) Old 03-19-2007, 10:30 PM
Banned
5 = open carrier, non trac-lok
well my tires did spin the oposite way before i rebuilt it so ionno lol
Porkchop is offline
post #21 of 45 (permalink) Old 03-19-2007, 10:34 PM
Yeah your differential might have been worn or something. Because some kid at the local In-N-Out hang out was trying to convince us of the same thing (jack the car up... wheels spin opposite ways it has some kind of traction lock) and we all had believed that they spin the same way if u had a posi or t-lock. But just to make sure we jacked up all our cars to see which way the wheels spun... And just as we thought they all spin the same way.
However, what's really strange is alot of Acura's/Honda's that dont have some kind of LSD still spin both wheels. Even at the track they spin both wheels. All my friends civics and integras without LSD spin both wheels while doing a burn out. And this ranges from stock engines to fully built stroker turbo/supercharger engine's. Thought i'd share that bit of strange information.
post #22 of 45 (permalink) Old 03-19-2007, 10:44 PM
Tim
Tim's Avatar
In park they tires go oposite but if in gear or nutruel they will both go the same direction.
Tim is offline
post #23 of 45 (permalink) Old 03-19-2007, 10:46 PM
Banned
HAHAHAH I TOLD YOU!!! itwas in the air and parked!!!
Porkchop is offline
post #24 of 45 (permalink) Old 03-19-2007, 10:51 PM
U didn't specify. I didn't even know the wheels could spin in park...
post #25 of 45 (permalink) Old 03-19-2007, 11:28 PM
Banned
i said it was on jackstands....what you think my car would be in reverse or drive? lol
NanaaaaaaanaaaaaNAA NAaahnhhh naaa
Porkchop is offline
post #26 of 45 (permalink) Old 03-19-2007, 11:43 PM
I just thought the wheels wouldnt spin at all so after you put it on stands you'd shift it into neutral or drive. Plus my stang is 5 speed. So there is no Park anyways. So naaaahhh naaaa naaaaa back to you
post #27 of 45 (permalink) Old 03-19-2007, 11:45 PM Thread Starter
wow thanks to all of you all for the info! Looks like a couple more hundred into the beast but I gotta do it!
post #28 of 45 (permalink) Old 03-19-2007, 11:51 PM
Banned
*puts head down* awwwww
Porkchop is offline
post #29 of 45 (permalink) Old 03-19-2007, 11:56 PM
AH HA! Victory is mine! Thought of the movie 300 there for a minute...
post #30 of 45 (permalink) Old 03-20-2007, 10:08 AM
Silenced's Avatar
Did you blind yourself with your HID's? Or do you just have a problem reading?
The person who I quoted (in the post you made this comment about) said not to use the gear to fix it because the teeth sheer off, and the transmission filter can't catch them. Weather that is valid or not, I have no idea. I was asking him for his suggestion as he might have found a better way of recalibrating everything with the 4.10s.
Powered by:
Silenced is offline
