Half Shaft Removal - TCCoA Forums
post #1 of 6 (permalink) Old 03-19-2007, 08:38 PM Thread Starter
Half Shaft Removal
The seal on my half shafts right at the pumpkin are leaking.
I know I need to remove the nut near the wheel.
Someone said that you just "pry" the halfshaft out of the pumpkin? Is there a c-clip or similar holding it in? If so do you have to remove the diff cover and remove the c-clip? Or have the cover off when you put it back in so you can reattach the c-clip?
Mine is a 97 t-bird, 7.5 inch rear end, non posi....
97TXBIRD is offline
post #2 of 6 (permalink) Old 03-19-2007, 09:50 PM
miller1995's Avatar
You do not need to remove the hub nut. Unbolt the bolts that connect the spinle to the upper and lower control arms and support the spinde with some thing, I ususllay use a milk crate. Slide under the car and use a pry bar or screw driver to pop the half shaft out of the differential. While holding up the upper control arm slide the spindle and half shaft until the shaft is out. Use a pry bar or a large screw driver to pry the seals out then tap the new ones in.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #3 of 6 (permalink) Old 03-20-2007, 08:36 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
for reference, the bolt heads are 18mm and the nuts are 21mm.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 6 (permalink) Old 03-20-2007, 09:40 AM
joshbea6's Avatar
I've done this swap MANY times as I've changed out my IRS MANY times.
18mm, and 21mm are your friends for this.
Also will need a 12mm to drop the rear caliper (assuming that you have rear disc). One thing to remember here if you DO have rear disc, is do NOT press on the brake pedal during this procedure, otherwise you need to re-adjust the caliper when you go to re-install it.
joshbea6 is offline
post #5 of 6 (permalink) Old 03-20-2007, 02:19 PM
when I did my rear end I took the nut off and popped it out of the spindle then used a prybar and pried on it by the differential and was careful not to damage the halfshaft. to me that was easy as pie.
97qwikcat is offline
post #6 of 6 (permalink) Old 03-20-2007, 02:37 PM
Motorboatin' SOB
big mike's Avatar
i just noticed you are in houston. if you need a hand, we can help you out.
2014 GT
1990 300ZX TT
big mike is offline
