gear question? - TCCoA Forums
post #1 of 12 (permalink) Old 03-20-2007, 01:26 PM Thread Starter
94fastbird's Avatar
Send a message via MSN to 94fastbird
gear question?
ok guys i just gears for my car there richmond gears 3.73 the guy from jegs said it would work for my car, but i looked at the pinion gear and it alot bigger than the stack pinion it looks more like a ford 9 inch pinion do u think this will work out i was told if the pinion bearing fits it should work. and i was also wondering what spline the pinion is it a 30 spline pinion? thats what i have
94fastbird is offline
post #2 of 12 (permalink) Old 03-20-2007, 01:37 PM
The Great Obucina's Avatar
is the gear set for an 8.8 ford? splines matter for your differential, not your gears.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 12 (permalink) Old 03-20-2007, 01:58 PM Thread Starter
94fastbird's Avatar
yes there for an 8.8
post #4 of 12 (permalink) Old 03-20-2007, 05:30 PM Thread Starter
94fastbird's Avatar
the guy at jegs said they'd work for my year of car i told him that i had an irs rear and he didn't know they did
post #5 of 12 (permalink) Old 03-20-2007, 05:32 PM
8.8 is 8.8 is 8.8. dont make is difficult.
post #6 of 12 (permalink) Old 03-20-2007, 05:35 PM Thread Starter
94fastbird's Avatar
i was just wondering cause the stock pinion gear is really small thats all i geuss i'll know alittle more when i get the rearend apart
post #7 of 12 (permalink) Old 03-20-2007, 05:37 PM
Boom.
Palmguy's Avatar
+1
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #8 of 12 (permalink) Old 03-20-2007, 05:39 PM
you really dont plan on installing those gears yourself, do you?
post #9 of 12 (permalink) Old 03-20-2007, 05:43 PM Thread Starter
94fastbird's Avatar
i was planning it but i heard it can be a pain so i thinking about taking it to a shop to get it done
post #10 of 12 (permalink) Old 03-20-2007, 05:44 PM
dont think it, do it.
post #11 of 12 (permalink) Old 03-20-2007, 06:40 PM
coggonobrien's Avatar
as far as size goes there will be a differance in the size of both ring and pinion depending on what gear ratio you use. you will also notice a differance in the angle of the teeh of the ring gear
coggonobrien is offline
post #12 of 12 (permalink) Old 03-20-2007, 06:43 PM
take it to a shop to have it install...really not worth trying to do yourself....too many variables to try to install yourself''''' good luck any way though
C F I FLY is offline
