Speedometer Correction for larger wheels? - TCCoA Forums
post #1 of 8 (permalink) Old 05-15-2007, 08:36 AM Thread Starter
Hittin' Switches
musto's Avatar
Send a message via AIM to musto
so i know the speedometer is soposed to be off, How do you fix the speedometer?
I would like it to show the accurate speed, also, does anyone know if you are running 245/35/20 tires, and your speedometer reads 60, how fast are you really going?
Matt Musto
musto is offline
post #2 of 8 (permalink) Old 05-15-2007, 08:41 AM
Use the Tire size cacluclator HERE to answer your question.
I think you can correct the speed for different size tires with the SCT-X Calibrator II.
post #3 of 8 (permalink) Old 05-15-2007, 08:55 AM
Eleventeenth Gear Poster
Aaron K.'s Avatar
You can also corrent your speedo with a Speedcal.
Aaron K. is offline
post #4 of 8 (permalink) Old 05-15-2007, 09:01 AM Thread Starter
Hittin' Switches
musto's Avatar
what does that consist of?
musto is offline
post #5 of 8 (permalink) Old 05-15-2007, 09:11 AM
Aaron K.'s Avatar
http://www.dallasmustang.com/page/speedcal.php
Aaron K. is offline
post #6 of 8 (permalink) Old 05-15-2007, 09:18 AM
fast Ed's Avatar
245/35/20 are close enough to the diameter as stock tires, that they shouldn't cause more than 1 or 2% speedo error.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #7 of 8 (permalink) Old 05-15-2007, 11:05 AM
The Great Obucina's Avatar
only on vehicles with a magnetic pickup VSS.....ours is gear driven.
"Booyah". Stu Scott.
The Great Obucina is offline
post #8 of 8 (permalink) Old 05-16-2007, 09:24 PM
CEO, WT Club
GODSPEED's Avatar
Ed is right, your size is close enough. You shouldnt be having problems.
-Joel
Previous MN12s:
GODSPEED is offline
