Tire size question - TCCoA Forums
post #1 of 6 (permalink) Old 05-30-2007, 12:06 AM Thread Starter
Tire size question
I got a free set of 235-70-R16 tires brand new off an SUV. I need new tires but can't afford em right now, are these too big to fit as a temporary for a week?
TBirdsRMachismo is offline
post #2 of 6 (permalink) Old 05-30-2007, 01:01 AM
jnk3846's Avatar
Stock Tire - 225/60R16 Tire 1 -235/70R16
Section Width: 8.85 in 225 mm
Section Width: 9.25 in 235 mm
Overall Diameter: 26.62 in 676.14 mm
Overall Diameter: 28.95 in 735.33 mm
Sidewall Height: 5.31 in 134.87 mm
Sidewall Height: 6.47 in 164.33 mm
Radius: 13.31 in 338.07 mm
Radius: 14.47 in 367.53 mm
Circumference: 83.62 in 2123.9 mm
Circumference: 90.94 in 2309.8 mm
Revs per Mile: 781.3
Revs per Mile: 718.4
Actual Speed: 60 mph
Speedometer1: 55.1 mph
Speedometer Difference: - Speedometer Difference: 8.755% too slow
jnk3846 is offline
post #3 of 6 (permalink) Old 05-30-2007, 10:48 AM
CrystalPistol's Avatar
Wink
Sure, they'll probably work OK .... but keep in mind that last part about your speedometer reading 55.1 while you are running 60 actual. The trooper's radar will be reading the actual speed. Extrapolating the 91.8333% true speed your reading will mean at an indicated speedo reading of 65, you'll actually be running 70.78 mph. At an indicated 75 you'll actually be cobvering ground at the rate of 81.669 miles per hour.
I wouldn't be pushing the speed limits and any "assumed" or "rumored tollerance" like that.
CrystalPistol is offline
post #4 of 6 (permalink) Old 05-30-2007, 11:43 AM
fast Ed's Avatar
I'm guessing that 29" tall tires are going to rub, especially on the front when turning.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #5 of 6 (permalink) Old 05-30-2007, 11:47 AM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Why not try and sell the brand new tires you got free for money towards properly sized tires for your car?
Sold = 96 Thunderbird
Aaron K. is offline
post #6 of 6 (permalink) Old 05-30-2007, 05:39 PM Thread Starter
Actually I'm taking them to the junkyard to trade for some tires that will fit haha.
