Smallest offest on a T-bird? - TCCoA Forums
post #1 of 8 (permalink) Old 06-07-2007, 10:01 PM Thread Starter
Beerdog80's Avatar
This might sound odd...but can someone tell me what the smalled offset a t-bird can use. I found some 19mm offset that would look great on my car but cant find any info on what can/cant be used.
Beerdog80 is offline
post #2 of 8 (permalink) Old 06-07-2007, 10:15 PM
miller1995's Avatar
Depends on what width wheel you want to use.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #3 of 8 (permalink) Old 06-08-2007, 08:42 AM
TCCoA Wheel Guru
If the wheel is for example 7.5" wide then it would sit in the wheel well 2MM more than a 9" wide wheel with a +36MM offset. You could probably hang a beer cooler from the control arms and not rub the wheels...Its like 40MM of inner clearance with that specific WIDTH wheel. Anything wider than 7.5" is going to look plain stupid though.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #4 of 8 (permalink) Old 06-08-2007, 04:33 PM Thread Starter
Beerdog80's Avatar
Brad
yeah....well the wheels I found when I made this thread were 7.5 wide but have a 40mm offset, combined with a 19mm spacer/adaptor so the wheels would fit. and thats not even assuring it would fit with proper sized tires so i just said hell with it. i'll just buy wheels made for tbirds. Seems like the easiest thing to do.
post #5 of 8 (permalink) Old 06-19-2007, 05:21 AM
decipha's Avatar
does anyone know if a 0mm offset on a 22x9.5 wheel will clear the control arms?
they will be wrapped in 305/45 tires
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #6 of 8 (permalink) Old 06-19-2007, 08:23 AM
It would clear the control arm by a mile, and stick out of the fender a couple of inches
Bangster is offline
post #7 of 8 (permalink) Old 06-19-2007, 08:37 AM
A 305/45/22 tire HAHAHAH good luck with that! YOu would need a 6 inch lift
maybe a 305/20/22
Bangster is offline
post #8 of 8 (permalink) Old 06-22-2007, 08:13 PM Thread Starter
Beerdog80's Avatar
I just said hell with it and got some centerline 15'' wheels right from the factory. seemed easier.
