17x 10 or 18 x 10 - TCCoA Forums
post #1 of 6 (permalink) Old 06-29-2007, 08:56 AM Thread Starter
94fastbird's Avatar
Send a message via MSN to 94fastbird
17x 10 or 18 x 10
has any one tried saleen wheels on there bird the 10 inch wide one if so any pics and if so would u need some spacers
94fastbird is offline
post #2 of 6 (permalink) Old 06-29-2007, 09:15 AM
I don't think you will have much luck with 10 inch wide wheels on the front. I have 9 inch wide wheels and that seems to be the limit (some would say over the limit, that puts them even with the wheel lip with about 3mm gap at the knuckle).
If you don't mind the wheels and tires sticking out of the fenders, then it might be possible.
Bangster is offline
post #3 of 6 (permalink) Old 06-29-2007, 09:24 AM Thread Starter
94fastbird's Avatar
well my concern was just putting them on the rear cause i want to run like a 315 / 35 /18 on the rear or in a 17 i would like a fairly wide tire on the rear
post #4 of 6 (permalink) Old 06-29-2007, 10:20 AM
Well, I assume you are looking at the aftermarket replica 17x10 18x10s for the up to 04 Mustangs? Probably not enough backspacing and a spacer would make it worse, not better. Get the specs of the wheels, mainly the backspacing, and that is a wide tire, I haven't looked at the back for clearances since I have narrow tires and mainly worried about the front.
Bangster is offline
post #5 of 6 (permalink) Old 06-29-2007, 12:23 PM
CEO, WT Club
GODSPEED's Avatar
Ok, seriously what the hell do you need that big of a tire for? Rims aside, you probly wont even be able to tuck that under the fender. Get a 275/285 - 40-18 and call it a day. You could even fit those on a 9" rim. Trust me I have played this 10" wide rear game and all it will do is end up frustrating you and/or spending a lot of money. If you want a 10" wide, talk to Cudaz101 for some of his billet options. Other than that, it's a guess and check game.
-Joel
Previous MN12s:
GODSPEED is offline
post #6 of 6 (permalink) Old 07-01-2007, 01:33 PM
TCCoA Wheel Guru
Here is one of my customers Cars with 18X9 SpeedStars.
255-40-18 Fronts "I would recomend 245-45-18"
275-40-18 Rears
Here is a pic of one of my own cars with the Speedstars. Tires are 245-45-18 front & rear.
1990 & 1994 SC's
cudaz101 is offline
