05-07 Mustang Rims - Do they fit?? - TCCoA Forums
post #1 of 16 (permalink) Old 07-31-2007, 07:34 PM Thread Starter
SplitPortBird's Avatar
Currently I have a set of 17x9 10th Anniversary rims with 275-40-17 tires all the way around on my thunderbird.
I only have probs with the rear rubbing on th tires with a full tank of gas or people in the car.
I have 3 options,, move to a 255 series tire and hope it doesnt hit anymore but I think it might.
Get a set of 94-04 Mustang GT (bullits) and tires 245-45-17 for a good price (these should fit)
OR get a set of 05-07 Mustang GT Bullits (look better then 94-04) but they come with 235-55-17 which would improve ride and fill out the fenderwell. but I'm not sure these will fit and might have to much backspacing???
Brad
SplitPortBird is offline
post #2 of 16 (permalink) Old 08-07-2007, 11:56 PM
MadGoat's Avatar
Send a message via AIM to MadGoat Send a message via MSN to MadGoat
Im working on this, I will have some 07 bullit rims mounted up with some235/55 r17 perielli pzero nero's on thursday.
Ill post with the pictures and issues (hope there arent too many).
~MG~
MadGoat's Birds
94 Thunderbird LX 4.6L PI
03 Aluminum PI Engine, J-Mod, Aluminum one piece drive shaft, 3.27's, 2.5" to single 3" custom MagnaFlow exhaust, 07 17x8 Bullit Wheels
97 Thunderbird LX 4.6L V8
RIP
MadGoat is offline
post #3 of 16 (permalink) Old 08-08-2007, 01:08 AM
Baby Huey
warmaster259's Avatar
Big Mike has some on his.
Jim
warmaster259 is offline
post #4 of 16 (permalink) Old 08-08-2007, 07:47 AM
Who is John Galt?
Yup:
http://forums.tccoa.com/showthread.php?t=99488
"Won't work, can't be done"
cougar_guy04 is offline
post #5 of 16 (permalink) Old 08-08-2007, 08:13 AM
Spacer will be necessary as the bullitt spoke design will interfere with the brake calipers, especially cobra or brembo calipers.
Mad1stGen is offline
post #6 of 16 (permalink) Old 08-08-2007, 12:08 PM Thread Starter
Have you verified this?? or speculation?
I am comparing rotors and calipers from SN95 and S197 mustangs and they seem close to identical.
The S197 used a 12.8"? rotor from the factory I believe which should be close to the 13" used on the SN95 Cobra's
Guess I'll be finding out the hard way as I just ordered a set of 17x8 Mustang (Bullet) rims and 235-55-17 P-Zero tires for my Thunderbird
post #7 of 16 (permalink) Old 08-08-2007, 12:28 PM
Verified 2005 OEM silver bullitts with 2004 13" rotors and cobra calipers.
1/4 spacer was needed. I can't speak for other wheel types though.
post #8 of 16 (permalink) Old 08-08-2007, 12:55 PM
jk69cat's Avatar
the old body has a 5.72 -5.98 backspace as where most of the 05+ are 6.82 backspace.
mn12 less!
jk69cat is offline
post #9 of 16 (permalink) Old 08-08-2007, 01:15 PM
Brad
Can't you just roll your fender lip a little to gain the extra clearance? That’s cheaper than your suggested options.
Just my .02.
69 F100 LWB w/460 Engine
post #10 of 16 (permalink) Old 08-08-2007, 11:58 PM Thread Starter
Damn,, better order the spacers before the wheels arrive
Is 1/4 inch the minimum needed? they have 5mm(1/4") and I also seen some 3mm (1/8")
post #11 of 16 (permalink) Old 08-14-2007, 12:41 AM Thread Starter
Well I just got my 2005 Mustang silver Bullet's and they fit fine without any spacers so I guess I just wasted my money buying a set of spacers I didnt need.
The front calipers are close yes,, but do not necsetate any need for spacers from what I can see.. I have about 1/8" between rim and caliper bracket and the calipers have new pads so they are extended outward as far as possible.
I'll have pics shortly, but all I can say is they fit awesome and look superb!
Brad
post #12 of 16 (permalink) Old 08-14-2007, 06:18 AM
Are you ruinning 13" rotors and dual piston calipers ? They were definitely needed on the car we worked on. They would scrape right at the cobra lettering. I have no reason to lie to you
post #13 of 16 (permalink) Old 08-14-2007, 08:42 AM
CEO, WT Club
GODSPEED's Avatar
Just FYI, a lot of aftermarket 05-07 replica wheels are very close to ideal spec, if not ideal spec for our cars after the hubswap. I have seen a bunch of replica rims in 9" widths, with +36mm offset, which is perfect.
-Joel
Previous MN12s:
GODSPEED is offline
post #14 of 16 (permalink) Old 08-14-2007, 01:39 PM Thread Starter
Yes running the 13" cobra brakes and the Actually COBRA (has the lettering also) twin pistons calipers.
Actually the closest item is the bracket with about 1/8" of space and the caliper itself has 1/4" of space.
AT MOST,, you would need a 1/8" spacer (3mm) and that would be just perfect cause the wheel would be almost equal with the fender lip.
I'm using a Actual Ford rim and it says it 17x8 and 45mm stamped inside the rim.
post #15 of 16 (permalink) Old 08-14-2007, 03:44 PM
MadGoat's Avatar
45mm means you have 6.295" of backspacing (max for the bird), 35- 37mm looks better on the bird as it brings the rim/tire combo out closer to the fender for a "beefier" look.
Im running same rims (17x8 45mm offset with 6.295" backspace off of a 07 mustang) with 1.25" bolt pattern spacer changers... doing the math... they look freakin sweeet!
~MG~
MadGoat's Birds
RIP
MadGoat is offline
post #16 of 16 (permalink) Old 08-14-2007, 06:41 PM Thread Starter
I'm debating on ordering a set of 3mm spacers to push them out a lil more,, to me they look perfect. also keeps the tires and rain inside the fenders instead of kicking it up under the rocker panels (where we need it the least!)
