fitment 255/55/18 - TCCoA Forums
post #1 of 11 (permalink) Old 08-30-2007, 04:30 PM Thread Starter
Send a message via AIM to Midgetchaser
fitment 255/55/18
will 255/55/18s fit on these cars? its lowered 1.5 inches, with the fender lip rolled up.
BrokeDickRacing
1987 thunderbird TC
Midgetchaser is offline
post #2 of 11 (permalink) Old 08-30-2007, 07:40 PM
Resident drifter
slidebird91's Avatar
1.5 inches isn't low enough to cause a problem, usually. that is 29" you are dealing with though. I can fit a 27 in mine barely, but im down 3 or 4 inches. the section width is 10 inches, which should fit in the back, but you may rub in the front when you turn
slidebird91 is offline
post #3 of 11 (permalink) Old 08-31-2007, 07:26 AM
TCCoA Wheel Guru
No...Don't do it...
245-45-18 or 255-45-18 or 275-40-18 rears...
1990 & 1994 SC's
cudaz101 is offline
post #4 of 11 (permalink) Old 08-31-2007, 03:17 PM Thread Starter
these are for the rears only sorry forgot to mention that.
BrokeDickRacing
1987 thunderbird TC
post #5 of 11 (permalink) Old 09-01-2007, 02:29 AM
TCCoA Wheel Guru
Those are gonna be some really TALL & HEAVY rear tires...
Brad
1990 & 1994 SC's
cudaz101 is offline
post #6 of 11 (permalink) Old 09-01-2007, 12:03 PM Thread Starter
traction. all of the 40, 45, even 50 tall tires dont hold. i need some more sidewall. plus its a better ride.
my cheap 225/60/16 hold better than the 235/50/18 bfg's i have now.
BrokeDickRacing
1987 thunderbird TC
post #7 of 11 (permalink) Old 09-01-2007, 11:14 PM
TCCoA Wheel Guru
The 255-55-18 is approx. 10lbs heavier than a 275-40-18...My guess is that you are not gonna have traction problems because of the massive power loss from such a Heavy & TALL tire.
What kind of power are you making with your SC anyways??
Brad
1990 & 1994 SC's
cudaz101 is offline
post #8 of 11 (permalink) Old 09-02-2007, 12:44 PM Thread Starter
not much 300-325 ish 3:73 in the rear. i drive it everyday and when i go to the track i like to just use my street tires to get a feel on how fast the car is on the street. i can put a 285 or a 315 if it would fit but with a 40 side wall and all its going to do at the track is spin.
BrokeDickRacing
1987 thunderbird TC
post #9 of 11 (permalink) Old 09-02-2007, 03:32 PM
sCrEaMiN BiRd's Avatar
Brad
Do you happen to have a picture of a bird with a 275/40/18. I'm debating on whether or not to go with a staggered set up for my next set of tires. Thanks!
sCrEaMiN BiRd is offline
post #10 of 11 (permalink) Old 09-09-2007, 06:17 PM Thread Starter
the 255/55/18s fit fine no rubbing in the wheel wells at all. rolled fender lip is a must.
p.s light truck performance tires are cheap!
BrokeDickRacing
1987 thunderbird TC
post #11 of 11 (permalink) Old 09-09-2007, 09:28 PM
Send a message via AIM to Red97Tbird
I have 275-40-18's in the rear on a 18x10.5 wheel and there is no rubbing. The wheel doesn't come out of the fender either looks nice and tucked.
Red97Tbird is offline
