Will Bullit 18x10 fit the Bird? - TCCoA Forums
post #1 of 46 (permalink) Old 09-15-2007, 05:05 AM Thread Starter
Here we are: Ford Mustang Bullitt/Bullet Style 18x10" Chrome (triple chrome plated) aluminum wheels (Car rims) Lug-pattern 5x4.50" +45mm offset (7.27" backspacing) On Sale - Free Shipping (deep dish).
Hub swapped! I plan to run 235/50 tires, suspension is standard height.
Creeper is offline
post #2 of 46 (permalink) Old 09-15-2007, 07:23 AM
miller1995's Avatar
A 235 is too narrow for a 10" rim, usually a 235 is for a 7" rim.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #3 of 46 (permalink) Old 09-15-2007, 10:18 AM Thread Starter
Well, I just want to get that "drift wheel look", when tires are narrower than rims.. I don't know about the problems that may emerge at these combination of parameters. Are there any? What can you say bout the quality of these wheels and generally what size is maximum possible for 18" rims with 24 offset. By the way my other car wears 195/50 tires on 7" rims and I consider the rims to be optimal for this size - can't even imagine what happens if I fit 235 on them!
They also got 18x10" +24mm offset (6.44" backspacing) (deep dish) What is preferable this or +45mm offset (7.27" backspacing) (deep dish) - (I'm going to use 4 piston calipers)
Creeper is offline
post #4 of 46 (permalink) Old 09-15-2007, 01:00 PM
VicRattlehead's Avatar
its not the drift wheel look, its the im to dumb and cheep to get the correct tires for the wheels i bought.
CMP Drag Racing
VicRattlehead is offline
post #5 of 46 (permalink) Old 09-15-2007, 02:22 PM
JMags's Avatar
195's on a 7 inch wheel! I'm running 255's on a 17x7" wheel.
Black '97 XR7
Magnaflow almost true duals w/ 3" rolled tips
Transgo bucking kit w/ aux cooler
JMags is offline
post #6 of 46 (permalink) Old 09-15-2007, 07:49 PM
MaleWhore
smokymance's Avatar
+1
perfect for those visits at the curb
smokymance is offline
post #7 of 46 (permalink) Old 09-15-2007, 08:46 PM
Chapter Director Coordinator
jamesD's Avatar
exactly
nice easy way to phuck up the rim on the wheel
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #8 of 46 (permalink) Old 09-15-2007, 09:20 PM
decipha's Avatar
going to small on the width of the tire will dramatically reduce traction and also increase wear, it also increases the chance of a blow out.
for a 7" width the skinniest i would go would have to be 215 (and thats cutting it)
for a 10" width skinniest would be a 275
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #9 of 46 (permalink) Old 09-16-2007, 07:03 AM
sCrEaMiN BiRd's Avatar
Sounds like you like the stretched sidewall look. I actually do like this type of style on certain cars. Some locals around here run stretched 275's on their E46 M3's and the like (mostly european cars) and i must say that i am in the club of bmw haters but i can't lie they do look nice. Their aggressive and makes the lip on the wheel stand out even more. However i will warn that if you ever have a blow out with a stretched sidewall it will not only destroy the wheel but be very dangerous as well. Just a word of caution. Plus if your car is stock height it wont look right anyways. Usually if a car has stretched sidewall tires it's for extra clearance in the wheel wells... AND please trust me on that, if your gonna get the balls to run stretched tires, you better be SLAMMED to the ground...
sCrEaMiN BiRd is offline
post #10 of 46 (permalink) Old 09-16-2007, 02:09 PM Thread Starter
Hate bimmers as well.
Creeper is offline
post #11 of 46 (permalink) Old 09-16-2007, 02:14 PM Thread Starter
Finally my question was forgotten.. Well. 9 or 10 inches, 255/45(40) tires, these rims gonna fit the wells or not? Shall I use spacers or stuff? Will the wheels catch body in turns? And what offset to prefer?
Creeper is offline
post #12 of 46 (permalink) Old 09-16-2007, 08:30 PM
fast Ed's Avatar
255/45/18 will fit with a bit of rubbing occasionally, depending on the ride height of the car. 255/40/18 will definitely fit.
9" at around +36 will fit all the way around. 10" is really too wide for the front, you can't get it tucked under far enough before it hits the spindle. Fine on the rear with around +35 to +40 offset, you will have to check e-brake cable and stab. bar clearance.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #13 of 46 (permalink) Old 09-18-2007, 11:05 AM
Send a message via AIM to Red97Tbird
I have 18x9's on the front with a 245-45-18 and it's lowered. I don't get any rubbing unless you count when I go over a dip. On the back I have 18x10.5 and 275-40-18 and they barely fit on the wheel that is. I have room in the back fine and it sit's up under the fender in the front and back. You can't ever tell there that wide from the side or back it's all tucked. I would not go any wider then a 9 inch on the front really close to rubbin.
Red97Tbird is offline
post #14 of 46 (permalink) Old 09-18-2007, 09:34 PM
U have pictures of the 10.5's?
post #15 of 46 (permalink) Old 09-19-2007, 07:03 AM
MaleWhore
smokymance's Avatar
+1....i want to really see how they fit and look from the back
post #16 of 46 (permalink) Old 09-19-2007, 09:26 AM
I'll Try and take some today. Just dont make fun of the primer on the kit
post #17 of 46 (permalink) Old 09-19-2007, 09:28 AM
MaleWhore
smokymance's Avatar
if u can, is there a way u can take a direct shot from the shot, and a direct shot from the back also....
post #18 of 46 (permalink) Old 09-19-2007, 09:40 AM
Shot from the Shot ?
post #19 of 46 (permalink) Old 09-19-2007, 11:40 AM
MaleWhore
smokymance's Avatar
ooopppss, side i meant.....my bad!!!
post #20 of 46 (permalink) Old 09-19-2007, 12:01 PM
LOL np thought thats what you meant
post #21 of 46 (permalink) Old 09-19-2007, 01:39 PM
Sorry if they suck, just took them at work on my camra phone. and it looks better when it's clean lol Those a 275-40-18's on 18x10.5's on a 5 on 4.5.
post #22 of 46 (permalink) Old 09-19-2007, 02:44 PM
MaleWhore
smokymance's Avatar
thats pretty good...whats the offset on those wheels....
post #23 of 46 (permalink) Old 09-19-2007, 02:49 PM
I don't know to be honest I just had them ordered we did a fit test with the Mustang hubs on and they worked lol IF you need the off set I can call where I got them from and find out.
post #24 of 46 (permalink) Old 09-19-2007, 04:39 PM
Thread Killer
midwestbird's Avatar
That tire should be a bit wider....no??
As of 10-20-06 DOHC POWERED
Painted Vista blue as of 08
242hp/251tq
[email protected] [email protected] Byron Il
RobertP plate modded: 5-23-08
midwestbird is offline
post #25 of 46 (permalink) Old 09-19-2007, 04:47 PM
Birdman232's Avatar
the 10.5's should have a 315 on em...thats what is on my stang...but i have 17x10.5, but you could probably use a 305 or 295 on them...275 is really stretching it on a 10.5
Birdman232 is offline
post #26 of 46 (permalink) Old 09-19-2007, 05:22 PM
Yea I know there small. When I get the new motor in i'll burn these off and get somthing wider
post #27 of 46 (permalink) Old 09-19-2007, 10:08 PM
Nice. You thinking about lowering?
post #28 of 46 (permalink) Old 09-20-2007, 07:31 AM
MaleWhore
smokymance's Avatar
would that fit with 305 or 315s on it on those wheels?
post #29 of 46 (permalink) Old 09-20-2007, 08:31 AM
It's lowered with eibach springs and tokico shocks and struts. In the front there is almost no fender gap at all , if i hit a dip in the road it rubs but thats the only time. 305's should fit on the back with out it rubbing. On the inside I still have about 2 inches before it will hit anything. I did run into a problem with the E-Brake rubbing on the wheel. Had to use clamps to keep it in tight to the car so it wouldn't rub.
post #30 of 46 (permalink) Old 09-20-2007, 11:59 PM
Your front is that low? You have pictures of the whole car? Shoot man i had to cut half a coil off the front of my eibachs to bring that sucker down to almost no fender gap...
