converting stock wheels to 5x4.5 - TCCoA Forums
post #1 of 10 (permalink) Old 09-18-2007, 07:08 AM Thread Starter
coggonobrien's Avatar
has anybody converted their stock wheels to the 5.45 bolt pattern? theoritically it shouldn't be a big deal to oblong the original stud holes an extra .25" a piece to make the change and once done there's no way the wheel can shift around on it. just a matter of making sure you are perfectly aligned when doing so. Dave
coggonobrien is offline
post #2 of 10 (permalink) Old 09-18-2007, 07:54 AM Thread Starter
thinking about it my more viable option may be to just drill the extra bolt pattern into my hubs and swap studs when swapping wheels. i am running extra long studs for my welds and i would only be swapping for winter use
post #3 of 10 (permalink) Old 09-18-2007, 12:05 PM
greencurse's Avatar
im sure you could just pick up a set of crappy GT wheels for next to nothing...
1997 Thunderbird LX, 4.6L, Performance White.
3.27 TL, 300hp J-Mod, Mid-Mount Magnaflow w/2.25" True Duals to 3" Magnaflow 15* Slash Cut Tips, PI Intake,
FR500 Steering Wheel, FRPP Wires, 180* T-Stat, 22C Plugs, Cobra Vert Rears, RSTB, SC "L" Braces. 175k and still flying!
greencurse is offline
post #4 of 10 (permalink) Old 09-18-2007, 12:10 PM
Traveler's Avatar
YEP. Better safety, and probably cheaper than all that machine work. and you can get 16" or 17" wheels depending on your needs.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #5 of 10 (permalink) Old 09-18-2007, 12:13 PM
Mod Motor Cat's Avatar
I went with the GT hubs up front, then redrilled new holes out back in the 5x4.50 pattern. Works just dandy.
~Brian~
*1990 Mustang Coupe, 5.4L*
Black on Black & Stroked 'n' Polked!!!
Mod Motor Cat is offline
post #6 of 10 (permalink) Old 09-18-2007, 12:39 PM Thread Starter
it really wouldn't take all that much machine work. i'm running mustang hubs now with redrilled tbird brakes on all four corners. the rotors were drilled with both patterns so it would just be a matter of throwing the hubs on a drill press with the rotors bolted on and drilling the extra holes
post #7 of 10 (permalink) Old 09-18-2007, 10:55 PM
Like Titles Matter
kdanner's Avatar
If you want excessive runout you can do it that way. If you want to do it right you use a vertical mill, with the hub on a rotary table.
1998 GT - [email protected]
generated by sloganizer.net
kdanner is offline
post #8 of 10 (permalink) Old 09-18-2007, 11:16 PM
MarksM's Avatar
Send a message via AIM to MarksM
Those rear hubs still holding up?
2007 Buell XB9S
MarksM is offline
post #9 of 10 (permalink) Old 10-06-2007, 04:30 AM
Kaptn' Obvious's Avatar
Send a message via AIM to Kaptn' Obvious Send a message via Yahoo to Kaptn' Obvious
Just open the phone book and pick any machine shop.
Five holes in a circle isn't exactly rocket science...
Mostly stock...
For now...
Kaptn' Obvious is offline
post #10 of 10 (permalink) Old 10-06-2007, 08:31 AM
miller1995's Avatar
My winter mustang wheels cost me $100, is it even worth all that effort?
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
