most backspacing on a 15" rim - TCCoA Forums
post #1 of 6 (permalink) Old 09-19-2007, 10:07 PM Thread Starter
coggonobrien's Avatar
what's the most back spacing you can run on a 15" rim on the front of one of our car's without any rubbing issues? i think if i can recall right the stock fanblades are 5" but not sure. Thanks, Dave
coggonobrien is offline
post #2 of 6 (permalink) Old 09-20-2007, 07:58 AM Thread Starter
i guess what i'm getting at is will a 5.5 backspacing work without hitting any of the suspension.
post #3 of 6 (permalink) Old 09-20-2007, 12:58 PM
MaddMartigan's Avatar
5.5 will work. I think you can pull off 6 IIRC.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is online now
post #4 of 6 (permalink) Old 09-20-2007, 01:16 PM Thread Starter
i knew 6 would work for the rears but wasn't quite sure on the front. thanks
post #5 of 6 (permalink) Old 09-20-2007, 01:31 PM
Well, I'm running 18x9's on the front so I can't say for sure.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #6 of 6 (permalink) Old 09-20-2007, 01:56 PM Thread Starter
alrighty i'll keep that in mind
