Custom Drag Wheels - TCCoA Forums
post #1 of 27 (permalink) Old 10-08-2007, 04:56 PM Thread Starter
TCCoA Wheel Guru
Custom Drag Wheels
I have some test wheels being made as of TODAY in the below spec/style.
Terminator Series Centerline Rotary Forged 2pc custom wheel.
They will be a direct bolt on wheel. No need to change studs or lugnuts, etc...Still have to do some test fitting but I see little to no surprises. I am posting this up to gauge interest. The prices are the absolute best I can do, I only wish I could do better...I was looking at doing a WELD Racing wheel but they are impossible to work with...Not to mention the fact that you have to change your lug studs and lugnuts to run them...IMO this is a better option AND they are willing to get things MOVING as well...heh
Prices are speculated @
$280ea Rears
$250ea Fronts
15X4 FRONT 13lbs 1.65" backspace Polished 5-4.25 bolt pattern
15X8 REAR 17lbs 5.50" backspace Polished 5-4.25 bolt pattern
All input is welcome...
Cheers,
Brad
1990 & 1994 SC's
cudaz101 is offline
post #2 of 27 (permalink) Old 10-08-2007, 04:58 PM
VicRattlehead's Avatar
15x6???? how bout 15x3.5 or 4
CMP Drag Racing
VicRattlehead is offline
post #3 of 27 (permalink) Old 10-08-2007, 05:09 PM Thread Starter
TCCoA Wheel Guru
Yea...I can get it done in a 15X4 if that is more desirable.
Thanks for the input..
Brad
1990 & 1994 SC's
cudaz101 is offline
post #4 of 27 (permalink) Old 10-08-2007, 05:16 PM
fast Ed's Avatar
Brad, I'm not in the market for them, for the guys who might be ... is the barrel on the 15x8" large enough to clear the 11.65" rear Cobra brakes? I know that some aftermarket 15" wheels do.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #5 of 27 (permalink) Old 10-08-2007, 05:20 PM Thread Starter
TCCoA Wheel Guru
cheers
Ed N.
Good point ED.
I could not say for sure...Will have to wait for the test wheels to show up. Then we can explore from there I guess.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #6 of 27 (permalink) Old 10-08-2007, 05:27 PM
Brad
yea the 4" is much better to put a 165r15 or mt front or d-10 tire on. the 6 is way to wide for a drag front.
CMP Drag Racing
post #7 of 27 (permalink) Old 10-08-2007, 07:12 PM
Any idea on how much they'll weigh?
-Rod
post #8 of 27 (permalink) Old 10-08-2007, 10:09 PM
driller's Avatar
How 'bout 16"?
driller is offline
post #9 of 27 (permalink) Old 10-08-2007, 10:12 PM
I like those a lot......
post #10 of 27 (permalink) Old 10-08-2007, 10:24 PM Thread Starter
TCCoA Wheel Guru
-Rod
Yea ROD...I posted a bit hastey I guess...heh...I edited the post.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #11 of 27 (permalink) Old 10-08-2007, 10:27 PM Thread Starter
TCCoA Wheel Guru
Originally Posted by driller View Post
How 'bout 16"?
This combination seems to be the most sought for and desired so that is what I decided on. I am sure its not going to be the answer for everyone unfortunatley.
What makes the 16" drag wheel so appealing to you??
Brad
1990 & 1994 SC's
cudaz101 is offline
post #12 of 27 (permalink) Old 10-08-2007, 10:40 PM
Brad
yea slicks are much more expensive for 16's and you dont get the big sidewall that the 15's have.
CMP Drag Racing
post #13 of 27 (permalink) Old 10-08-2007, 11:34 PM
sCrEaMiN BiRd's Avatar
I like those as well. I would also like to know if those will clear the rear cobra brakes however.
sCrEaMiN BiRd is offline
post #14 of 27 (permalink) Old 10-09-2007, 08:15 AM
driller's Avatar
Brad
The Mark VIII has 16" wheels.
I guess the real question is will the 15" wheels clear the brakes on the FN10 chassis?
driller is offline
post #15 of 27 (permalink) Old 10-09-2007, 12:39 PM Thread Starter
TCCoA Wheel Guru
I am pretty damn sure that the MarkVIII guys have been using Tbird 15X7 wheels for drag tires for quite some time now...??
Yea...I know that the mark uses a 16" wheel...haha...And that the brake clearance is a lil differant. Its not THAT differant though. I don't think fitment will be a problem at all, front or rear.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #16 of 27 (permalink) Old 10-09-2007, 01:58 PM
fast Ed's Avatar
I don't think the 15s will clear the Mark VIII front brakes, but the different shape of the barrel on the aftermarket wheels might be the difference.
cheers
Ed N.
fast Ed is offline
post #17 of 27 (permalink) Old 10-10-2007, 10:36 PM
Refrigerator Raider Hater
GreenBird's Avatar
I don't think the 15s will clear the Mark VIII front brakes.
They could always upgrade to PBRs for the "LX" brake rotor.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #18 of 27 (permalink) Old 10-12-2007, 07:16 AM
392Bird's Avatar
Did you look into 6 inch BS for the rear? They fit fine on mine. If a problem, maybe 5.75? I hate to get the tire sticking out.
Here is 15x8 with 6 inch BS.
Those are 275/50/15 MT ET Drags
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #19 of 27 (permalink) Old 10-12-2007, 07:23 AM Thread Starter
TCCoA Wheel Guru
Max backspace for the barrel is 5.50"...Even when I was working with WELD 5.50" was going to be the max on their barrel as well.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #20 of 27 (permalink) Old 10-12-2007, 07:38 AM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
cheers
Ed N.
If you get the grinder out,then the 15x8 Telstar will clear.I'm using your brackets with the rear cobra rotor,and I had to get happy with the grinder on the rear calipers to get it to work. I'm using a 15x8 with a 5.5" BS in the 5x4.5 pattern.
JL
Fuelly
Johnny Langton is offline
post #21 of 27 (permalink) Old 10-12-2007, 11:03 AM
392Bird's Avatar
I am Ready.......
392Bird is offline
post #22 of 27 (permalink) Old 10-12-2007, 11:20 AM Thread Starter
TCCoA Wheel Guru
Originally Posted by 392Bird View Post
I am Ready.......
I am glad that the ball is actually rolling on this. When I SEE the test wheels I will be EXCITED...
I believe that its just a matter of time at this point.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #23 of 27 (permalink) Old 10-12-2007, 12:54 PM
I am Ready.......
Do you want to sell the rear wheels you have now? The widened spare wheels?
post #24 of 27 (permalink) Old 11-04-2007, 08:59 PM
paintme205's Avatar
any updates...... I really like the idea of drag wheels in tbird bolt patterns for once.
paintme205 is offline
post #25 of 27 (permalink) Old 11-04-2007, 09:09 PM Thread Starter
TCCoA Wheel Guru
Originally Posted by paintme205 View Post
any updates.......???
Actually YES...I failed to update the thread here at the TCCoA.
Recieved the TEST WHEELS on Friday (Last) and have done Test fitting Saturday (Yesterday). Only a matter of time until I place an order.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #26 of 27 (permalink) Old 11-12-2007, 07:21 PM
paintme205's Avatar
well let us know when you get them.....christmas is soon lol!
post #27 of 27 (permalink) Old 11-13-2007, 07:48 PM
954.6tbird's Avatar
YES!!! let us know!
i will be purchursing(sp)!!!!!
Ed
94 Thunderbird 4.6 PI
954.6tbird is offline
