wider rear rims ?? - TCCoA Forums
post #1 of 3 (permalink) Old 11-01-2007, 09:47 PM Thread Starter
wider rear rims ??
I've tried searching but I cant seem to find any info on wider rear rims for use at the track. All I've got is a set of stock Taurus 15" steel rims that I used at the track with 235/60/15 drag radials but I would really like to find a wider 15" rim so I can go with a wider drag radial as well. I think the rims I'm using are either 6 or 6.5" wide but I would really like something at least 7.5 to 8".
If anyone knows who makes them in the stock 5 x 4.25 bolt pattern please let me know and post a link if you've got one.
Jon
1996 T-bird, 4.6 with ported PI heads and VT stage 2 cams, JBA shorty headers, 3000 stall converter, 3.73 gears and just about every bolt on available.
Dyno tune results: 275.9rwhp and 301.4 torque.
Best 1/4 mile time: 13.65 at 99.52 mph.
Now I need more gear, more stall and some drag radials !!
QkTbird is offline
post #2 of 3 (permalink) Old 11-01-2007, 10:39 PM
94fastbird's Avatar
Send a message via MSN to 94fastbird
i know a supercoupe wheel is only a half inch wider than stock 16x7 i've seen guys runnning 245/50/16
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #3 of 3 (permalink) Old 11-02-2007, 08:40 PM
While wider wheels would be ideal, you can run a relatively decent sized tire on the 16x7" SC or XR7 wheels. I run a pair of 28x11.50-16's on XR7 7 spokes, which works very well.
-Rod
