Slightly different tire for stock t-bird - TCCoA Forums
post #1 of 16 (permalink) Old 11-01-2007, 10:58 PM Thread Starter
FJK
I'm getting a 95 T-Bird LX from a friend, really soon. The only thing it needs is tires. It currently has stock 215-70 X 15. I have a set of almost new 225-60 X15. Does anyone see a problem? Thanks, FJK
FJK is offline
post #2 of 16 (permalink) Old 11-01-2007, 11:03 PM
The Great Obucina's Avatar
no, none at all. the tires will be fine.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 16 (permalink) Old 11-01-2007, 11:20 PM
94fastbird's Avatar
Send a message via MSN to 94fastbird
i've got 255/60/15 on my rear i've ran 275/50/15 there really tight on bead i blew it off once so i went with a smaller tire, the 275/50/15 is to wide for the stock rim. it would work out fine what ur talking about
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #4 of 16 (permalink) Old 11-02-2007, 03:47 AM
jnk3846's Avatar
There going to look small and your speedo is going to read fast.
jnk3846 is offline
post #5 of 16 (permalink) Old 11-02-2007, 08:23 AM
CEO, WT Club
GODSPEED's Avatar
Those tires are about 1" shorter than stock. Unless you like wheel gap and bad speedo readings ftw... get the right tires.
-JOel
Previous MN12s:
GODSPEED is offline
post #6 of 16 (permalink) Old 11-02-2007, 08:53 AM
coggonobrien's Avatar
275/60 r15 work fine on a stock fan blade. i did it for two years only problem is premature wearing of the middle if you run at full pressure. drop to around 30 to flat out the tread and you are good to go
coggonobrien is offline
post #7 of 16 (permalink) Old 11-02-2007, 01:30 PM
jnk3846's Avatar
Bad Advice, Way too big of a tire for a 6.5 rim.
jnk3846 is offline
post #8 of 16 (permalink) Old 11-02-2007, 02:51 PM
how so. u can call it bad advice but i never had any problems with it. daily drove in temps from -15 to 100, storm, and snow and i have never broke a seal or had any accidents as a result
post #9 of 16 (permalink) Old 11-02-2007, 03:27 PM
while you can fit the tire, its a bit much....the limited rim width of only 6.5inches coupled with a relatively tall tire/high sidewall can cause excessive sidewall flex because much of the tire is just not support by the rim.
post #10 of 16 (permalink) Old 11-02-2007, 04:57 PM
Tire specs i've looked at say min. 7" rim width for that size tire. It might be do-able but i wouldn't call recommending something narrower good advice.
Southpaw is offline
post #11 of 16 (permalink) Old 11-04-2007, 08:25 PM Thread Starter
FJK
Well, I finally picked up the 95. I'm excited to start driving it. From the replys so far, I'm considering the correct 215 x70-15 tires. Looking at the tire rack, tires of that size seem limited & for every good review, there is always someone who has something bad to say about any particular tire.
Anyhow, I was doing some "looking" at this 95 & I could use some addtional info. The stock 7 spoke wheels are marked "right side" & "left side". Why is that? Also, how wide are those wheels? 7"? Finally, what is the lug nut torque spec? I set them at 85 ft-lbs.
Thanks, FJK
FJK is offline
post #12 of 16 (permalink) Old 11-04-2007, 10:13 PM
jnk3846's Avatar
the wheels are 6.5 there also directional wheels 2 go one way and 2 go the other way that why they are marked left and right.
jnk3846 is offline
post #13 of 16 (permalink) Old 11-08-2007, 05:21 PM
nall_one's Avatar
you guys should just go to a tire caluculator http://www.miata.net/garage/tirecalc.html just enter 215/70/15 then what you want and it will tell you if it will work. i find 245/60/15 is really close. so im betting thats the biggest you can get without looking stupid.
nall_one is offline
post #14 of 16 (permalink) Old 11-09-2007, 12:37 AM
Traveler's Avatar
I went with 245/60/15's when I had the 15" wheels. They look great, and most important THEY FIT SAFELY. I would not go any bigger than a 245 on the stock 15" wheels.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #15 of 16 (permalink) Old 11-18-2007, 08:22 PM
i definately agree with traveler. 245/60/15 are going to the best look, performance and safety for the stock fanblade wheels. ran several sets of this size....you will not regret it.
obviously others think different, but i think you will find the MAJORITY of opinions from experienced people will back this up.
1994 Thunderbird - Renegade Racing Long block, TFHS Trans, NA/SVO intake. Cam94 lives!
2010 Shelby GT500 - Black/Silver
1995 Thunderbird LX - 2000 GT PI Swap by W&S Motorsports - Sold on Tccoa.
Bill H is offline
post #16 of 16 (permalink) Old 11-19-2007, 09:41 PM Thread Starter
FJK
Well, for old farts, such as myself, I decided not to "trick up" the tire situation & went with stock size 215-70X15. Decided on Michelin Harmony from Tire Rack. Nice ride, quiet, good response tires. I have only 50 miles on them, but feel it was a good choice for the type of use of the car. Much better than the OEM 680 Firestones, but they were so shot, any thing would have been better.
Thanks everyone for your responces. FJK
FJK is offline
