17x 10 18x10 wheels - TCCoA Forums
post #1 of 5 (permalink) Old 12-17-2007, 11:53 PM Thread Starter
94fastbird's Avatar
Send a message via MSN to 94fastbird
17x 10 18x10 wheels
what would be the max size tire for 17x10 or 18x10 wheel for the rear, that would look good for the bird lowered 1.5 to 2inch, with mininmal fender gap.
any suggestions.
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #2 of 5 (permalink) Old 12-18-2007, 08:24 AM
fast Ed's Avatar
275/40R18 is a nice size, width is good as well as diameter. In 17", there aren't really any tires wide enough for 10" wheels that have enough diameter, if you want minimal fender gap. Many people run 275/40R17, but that size will be roughly 1" shorter than the stock tire size, and our cars have big wheelwell openings.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #3 of 5 (permalink) Old 12-18-2007, 10:46 AM Thread Starter
94fastbird's Avatar
yea thats the bad thing, i dont like alot of fender gap, i have notcies when ppl run a 275/40 theres still quite an bit of fender gap on a lowered car. i was think in the lines off a 295/35/18 or a 315/35/17 but that that 315/35/17 tires rim width is suggested for a 10.5 rim not a 10inch and was wondering maybe if anyones done that. i was thinking bigger for the 18 to
Current Mods:
Future Mods:
post #4 of 5 (permalink) Old 12-18-2007, 11:42 AM
fast Ed's Avatar
315/35R17 will be the same diameter as 275/40, too short. And a 315 is going to be hanging out anyway. 295/35R18 is only about 1/2" shorter than stock. Charles Brown has that size on his 95 SC, but they are stuck on 8-1/2" or 9" wheels I believe. 285/40R18 is another option, actually a bit taller than stock. With increased wheel diameter, you can tuck the wheels a bit further under on the rear, to a point, since the barrel of the wheel is away from the outboard point of the rear stab. bar.
cheers
Ed N.
fast Ed is offline
post #5 of 5 (permalink) Old 12-18-2007, 02:45 PM Thread Starter
94fastbird's Avatar
yea cause i think i might get the smoothies or junkyard dogs from brad, with the wide ones in the rear, and the 8 inch rims in front i like the staggered affect
Current Mods:
Future Mods:
