what size tires are you running on an 18x9 - TCCoA Forums
post #1 of 17 (permalink) Old 12-21-2007, 05:49 PM Thread Starter
Illinois Chapter Director
TydlwavS's Avatar
Send a message via AIM to TydlwavS
Pictures would also be helpful. I am looking at 18x9's with the 24mm offset and a 1.5 drop. I prefer minimal fender gap on my cars. I'll be running a larger tire (drag radial) in the rear on the street.
I am leaning towards a 255 up front, but I'm not sure what sidewall dimension I want to run.
Todd
"That is the worst looking car in the whole world. I'd rather look at one of your dingle berries"
Check out what we've been up to....
http://forums.tccoa.com/forumdisplay.php?f=54
TydlwavS is offline
post #2 of 17 (permalink) Old 12-21-2007, 07:08 PM
96bird's Avatar
A 255/45 will be about 27" tall tire. I am personally looking for an 8.5" wide wheel with a 245/45 for a 26.7" tall tire. The 255 will definitely have a minimal fender gap with a 1.5" drop. I think it might rub with that offset though. I should know in the spring when I get the wheels to see for myself.
Russell
96bird is offline
post #3 of 17 (permalink) Old 12-21-2007, 08:54 PM
13's or Mildly Broken
18x9 on the rear running a 255/45 tire with Eibach lowering springs. Here's a pic
That's the best pic I've got to give you an idea of the wheel gap. I can take one from a different angle if you like - just let me know. I'm very pleased with what wheel gap there is. Not too bad, but doesn't appear to be a 4x4 either.
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #4 of 17 (permalink) Old 12-21-2007, 08:56 PM
96bird's Avatar
That looks almost perfect to me Melon.... I can't wait until I get mine. Is that a +36mm offset?
Russ
96bird is offline
post #5 of 17 (permalink) Old 12-21-2007, 10:02 PM
-Melon
I guess a good comparison would be the other thunderbird behind your car.
Hobohuey is offline
post #6 of 17 (permalink) Old 12-22-2007, 03:50 AM
TCCoA Wheel Guru
Todd
Todd, with a 24mm offset you are going to have fender clearance issues with a 255mm tire. Being lowered is only going to pronounce those challenges even more.
With the SC a 245-45-18(front or rear) is the size I would recomend to stick with & a 275-40-18(rear) if you want a staggered set. You won't have fender gap if you lower the car. The LX could use a lil more height (As the car that has been posted up).
I have to say though....The appearance of a 9" wide wheel with a +24mm offset on our cars is laughable IMHO...
Cheers,
Brad
1990 & 1994 SC's
cudaz101 is offline
post #7 of 17 (permalink) Old 01-02-2008, 01:17 AM
255 on the front and 275 -18 on the rear
25svo is offline
post #8 of 17 (permalink) Old 01-02-2008, 07:14 AM
miller1995's Avatar
255-45-18 on all four corners.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #9 of 17 (permalink) Old 01-04-2008, 07:56 PM
Boost Happy
Jurgen's Avatar
Send a message via AIM to Jurgen
245/45/18 & 275/40/18 next tire change i will go 285/40/18
Jurgen
1994 Ford Thunderbird
2002 Corvette Z06
Yeah I got a few mods.And Some More
http://www.cardomain.com/ride/239875
Jurgen is offline
post #10 of 17 (permalink) Old 01-05-2008, 03:03 PM
VicRattlehead's Avatar
mine are 245x45 front, 275x40 rear i have airbags in back so the fender doesnt rub. and your old H&R springs out back.
CMP Drag Racing
VicRattlehead is offline
post #11 of 17 (permalink) Old 01-05-2008, 05:47 PM
SC V8 Bird's Avatar
Send a message via Yahoo to SC V8 Bird
Todd
I wouldn't recommend it, even running 245's on front you will probably rub when at hard turn in reverse, not to mention a more serious bump steer problem with larger than a 245 up front.
Unless you do some modifications up front with new hub assemblies, a bump steer kit, offset wheels and/or modifying the fenders.
SC V8 BIRD
TCCoA Gallery
http://forums.tccoa.com/vbpicgallery.php?do=view&g=45
Car Domain
http://www.cardomain.com/ride/2527375
NW Late Model Thunderbirds & Supercoupes Myspace Group
http://groups.myspace.com/nwlatemodelthunderbirds
SC V8 Bird is offline
post #12 of 17 (permalink) Old 01-07-2008, 07:16 PM
jesusraybrown's Avatar
Jurgen
I don't mean to get off topic, but this is the single most bad-ass picture of a t-bird EVER. You're a lucky man Jurgen.
1. This forum requires that you wait 30 seconds between sending private messages. Please try again in 266079416 seconds. wtf?
jesusraybrown is offline
post #13 of 17 (permalink) Old 01-07-2008, 07:50 PM
TCCoA Wheel Guru
Lets just keep in mind that NONE of the tire setups on any of the photos in this thread will even come close to being in the same position as the setup he is talking about.
Jurgen has an 18X9 with +36MM offset which is the perfect position for a 9" wheel on our cars.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #14 of 17 (permalink) Old 01-07-2008, 07:56 PM Thread Starter
TydlwavS's Avatar
Thanks guys. I am looking at some different options right now. Since I can't seem to sell my Bogarts I am looking for options in our lug pattern. I don't like chrome and I'm not a fan or 19" or larger.
TydlwavS is offline
post #15 of 17 (permalink) Old 01-07-2008, 08:06 PM
Have you considered the 18" x 9" Gun Metal Grey R's?
post #16 of 17 (permalink) Old 01-07-2008, 09:25 PM
miller1995's Avatar
My wheels are also 36mm offset.
-Miller
SOLD1998 Escort ZX2
post #17 of 17 (permalink) Old 01-07-2008, 09:28 PM Thread Starter
TydlwavS's Avatar
I don't care for that color on a white car. I'd prefer the silver if they were made. I truly want a set of silver 17x9 R's.
TydlwavS is offline
