5x4.5 hub swap - TCCoA Forums
post #1 of 20 (permalink) Old 12-22-2007, 08:29 PM Thread Starter
auto alchemist's Avatar
5x4.5 hub swap
can anyone tell me how to do this swap, ive read an article on how to do it but they went into way to much detail and i didnt really understand how to do it after i read it
and can you list what parts from what years of mustang i need
auto alchemist is offline
post #2 of 20 (permalink) Old 12-22-2007, 08:35 PM
94-04 mustang front hubs, 94-04 mustang front rotors, 99 cobra rear hubs, redrilled tbird rear rotors or drums, and bearings and nuts should be replaced as well
post #3 of 20 (permalink) Old 12-22-2007, 08:38 PM Thread Starter
so prety much its just like replacing the stock hubs except with mustang hubs?
post #4 of 20 (permalink) Old 12-22-2007, 08:40 PM
yep, plus finding a machine shop to drill the stock rear rotors
post #5 of 20 (permalink) Old 12-22-2007, 08:42 PM Thread Starter
ok thanks, its alot easier then what i thought it was going to be lol
if i do this i will miss being able to use my stock fan blades though
post #6 of 20 (permalink) Old 12-22-2007, 09:10 PM
ClintD's Avatar
Is it possible do use lincoln Mark-III hub's for this swap?
ClintD is offline
post #7 of 20 (permalink) Old 12-22-2007, 09:36 PM
mark viii hubs are the same pattern as mn12's
post #8 of 20 (permalink) Old 12-22-2007, 09:44 PM
ClintD's Avatar
Are you serious!!
I thought the mark III was considered a Full-size.
ClintD is offline
post #9 of 20 (permalink) Old 12-22-2007, 09:46 PM
yep, mark viii's are almost the same platform as the mn12
town cars are the full size lincolns, those hubs dont work either btw
post #10 of 20 (permalink) Old 12-27-2007, 08:42 AM
1WLD BRD's Avatar
Send a message via AIM to 1WLD BRD
so you can use the stock calipers? just need the stang rotors, hub on the front?
My Cougar Domain
XBox Live: cn1WLD BRD
1WLD BRD is offline
post #11 of 20 (permalink) Old 12-27-2007, 03:15 PM
yep, right now i'm running the stock calipers
post #12 of 20 (permalink) Old 12-27-2007, 03:32 PM
PostSkank
StupidFly's Avatar
The other option for the rear is using Cobra rear rotors and the stock rear calipers (this is all assuming you're using rear discs) with a set of Fast Ed's brackets
math > pasta
StupidFly is offline
post #13 of 20 (permalink) Old 01-15-2008, 04:25 AM Thread Starter
ok im bringing tis thread back because i started pricing some stuff for the hub swap and its seems every site i check online when i look for a 99 cobra rear hub assy. it gives me this and from the pic it looks like its just the bearing, heres an example....
http://www.oreillyauto.com/EW3/Produ...&currentPage=0
so if this is not what i need where did everyone else get their hubs from?
post #14 of 20 (permalink) Old 01-15-2008, 07:45 AM
It is item #3 in the drawing. (This site is a nice place for "research" because they often have exploded views of a lot of systems.... )
http://www.trademotion.com/partlocat...layCatalogid=0
I don't know if any of the auto parts places will carry that hub. You can probably beat their $90 (each) price by shopping around.
Here's a better picture of what you need:
http://cgi.ebay.com/ebaymotors/FORD-...2em118Q2el1247
I found this on eBay:
http://cgi.ebay.com/ebaymotors/Mark-...spagenameZWDVW
69 F100 LWB w/460 Engine
post #15 of 20 (permalink) Old 01-15-2008, 10:46 AM
joshbea6's Avatar
Check with the ford parts counter here for the hub swap items. I got a GOOD price quote from them when I was doing research on it.
joshbea6 is offline
post #16 of 20 (permalink) Old 01-16-2008, 05:33 AM
Smile Online OE parts
Another good place to shop online for OE parts and lower price....
http://www.trademotion.com/partlocat...?siteid=213787
The hubs are about $75 instead of $90, for example. And drawings are available as well.
ron
ronnshf is offline
post #17 of 20 (permalink) Old 01-16-2008, 12:04 PM Thread Starter
so does anyone know if i can use tbird front rotors also if i have them redrilled, because i already have a brand new set of front rotors that i never used from my other tbird, and if i just had those redrilled it would save me some money on buying rotors
post #18 of 20 (permalink) Old 01-16-2008, 06:54 PM
tbirdtess's Avatar
Cost??
Hello
What will it cost for Redrilling?
I purchased new rotors for mine at the Zone. I didn't think they were Expensive.
I would check cost first!
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #19 of 20 (permalink) Old 01-16-2008, 08:39 PM
dont bother getting the fronts redrilled, it will cost less for new stang ones.
post #20 of 20 (permalink) Old 01-16-2008, 10:53 PM Thread Starter
i know a couple guys that work at machine shops so i can get work done prety cheap
