wheel bearings - TCCoA Forums
post #1 of 6 (permalink) Old 01-04-2008, 05:52 PM Thread Starter
SR-71Blackbird's Avatar
wheel bearings
to replace the front wheel bearings do you have to replace the whole hub
1997 4.6L LX SPORT, rollin on 19's
http://www.cardomain.com/ride/856858
http://s12.photobucket.com/albums/a241/steviewonder13/
PI heads, PI intake, Comp 262's, Comp Valve Springs, Kooks headers, 3.73 TL, 180*T-stat, RSTB, lowered 1.5", A/C Delete Pulley, Custom exhaust. Block #2
-- SCT dyno tune 279RWHP & 310RWTQ - DD tune, SAE corrected
14.5 @ 97mph (need a higher stall, car bogged w/ stock converter + mickeys, lol)
SR-71Blackbird is offline
post #2 of 6 (permalink) Old 01-04-2008, 06:06 PM
LOLA's Avatar
Yes.
LOLA is offline
post #3 of 6 (permalink) Old 01-09-2008, 07:09 AM
MaleWhore
smokymance's Avatar
are the mark viii hubs the same as the thunderbird hubs?
smokymance is offline
post #4 of 6 (permalink) Old 01-09-2008, 07:34 AM
Basically... (I think) all the Mark VIII hubs have the ABS rings on them, whereas the T'bird ones may or may not depending on if the T'bird had ABS or not.
69 F100 LWB w/460 Engine
post #5 of 6 (permalink) Old 01-09-2008, 07:37 AM
MaleWhore
smokymance's Avatar
i just checked the part numbers for the later tbrd and mark (97 sport vs 98 LSC), both with abs standard, and they were the same....
my mark has a bad hub and the tbird has new ones, but getting swapped to a 4.5 x 5 pattern, so im making the swap!
post #6 of 6 (permalink) Old 01-09-2008, 07:47 AM
Cool!!!
Just be careful on the offset of the wheels, my 17 x 8.5's that fit great on my 94 T'bird, rubbed on my 97 LSC. The rear fender area on the Mark VIII goes "inward" vs. the T'bird that actually has a small fender flare.
I ended up with this setup: TSW Kyalami 17 x 8, Cobra brakes, w/245 50 17 Pirelli's:
Sorry for the hyjack, just a little shameless back patting....
