265/60TR16 tires? - TCCoA Forums
post #1 of 16 (permalink) Old 01-16-2008, 01:25 PM Thread Starter
alicks's Avatar
265/60TR16 tires?
Okay, so, I read an earlier post on RWL tires and, upon seeing pictures, said to myself, "Damn, that looks nice!" Seeing as I actually need new tires at the moment, I figured that it'd be a good time to look into some RWL tires.
The BF Goodrich Radial T/A tires look pretty nice and have good reviews, but I've got one question - the smallest size they come in for 16" rims is 265/60TR16. My question is, then, will these fit on stock Sport wheels? And more importantly, if I mount these tires on 16" Sport wheels on a '97 Sport, will I encounter any fit problems? Will there be any rubbing, etc.? I'm kinda new to this whole thing, so what I know about, well, anything, you can just about fit in a thimble, so any advice or help would be greatly appreciated. Thanks.
alicks is offline
post #2 of 16 (permalink) Old 01-16-2008, 01:29 PM
LOLA's Avatar
This will give you an idea of how much bigger the 265/60/16 is.
http://www.1010tires.com/TireSizeCalculator.asp
LOLA is offline
post #3 of 16 (permalink) Old 01-16-2008, 01:45 PM
fast Ed's Avatar
Maybe on the rear, but I'm guessing tires that wide and tall would rub all over the place on the front (as well as look pretty goofy).
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #4 of 16 (permalink) Old 01-16-2008, 01:45 PM Thread Starter
alicks's Avatar
Aha, thanks. That pretty much settles it - it's a no. How sad.
With that in mind, then, does anyone know of/recommend any good RWL tires that'll fit on stock 16" wheels?
(as a point of reference, I believe the stock tire size is 225-60-16)
alicks is offline
post #5 of 16 (permalink) Old 01-16-2008, 01:57 PM
You might want to rethink the RWL vs. tire price and size availability. Sadly, RWL tires are getting hard to find and you are really limiting yourself in tire selection.
I have always liked the 235 60 16 for a nice, cheap, readily available tire that fits nicely on the 16” wheels. They aren’t that wide but there are many to choose from.
But just my opinion.
69 F100 LWB w/460 Engine
post #6 of 16 (permalink) Old 01-16-2008, 02:05 PM Thread Starter
alicks's Avatar
Well, cheap and readily available is definitely a plus - it just so happened that I saw these RWLs and really liked the way they looked, at least from the side.
It's not really the width that appealed to me, just the lettering. I guess, then, I'll just have to settle for "normal" tires, seeing as I haven't been able to find ANY RWLs that'll fit. Oh well.
alicks is offline
post #7 of 16 (permalink) Old 01-16-2008, 02:11 PM
jnk3846's Avatar
jnk3846 is offline
post #8 of 16 (permalink) Old 01-16-2008, 07:18 PM Thread Starter
alicks's Avatar
Aha! Thanks.
alicks is offline
post #9 of 16 (permalink) Old 01-16-2008, 08:13 PM
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
Might check out the Dayton Daytona SR, that's what I had on my '92, they looked sharp. RWL on a white Bird looks awesome, IMO
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #10 of 16 (permalink) Old 01-16-2008, 09:16 PM Thread Starter
alicks's Avatar
How was treadwear and performance on 'em?
Also: I see for 16" rims, they only come in 235-55-16. Does anyone have any idea how that'd look? Any advice?
alicks is offline
post #11 of 16 (permalink) Old 01-24-2008, 01:00 AM
The_Ghost's Avatar
255/60r16 Ftw
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #12 of 16 (permalink) Old 01-27-2008, 08:36 PM
So, I take it that 235 60 16's will fit on a 97 with sport suspension? I had a 88 Turbo Coupe and bought some that size and had rubbing issues.
TXTBird
Houston, Texas
TXTBird is offline
post #13 of 16 (permalink) Old 01-27-2008, 09:07 PM Thread Starter
alicks's Avatar
Actually, I don't know, I still haven't bought any new tires yet. I probably should.
- Alex B.
Ranger Up - Not everyone's war stories end in high school.
Out of the Thunderbird game for now.
alicks is offline
post #14 of 16 (permalink) Old 01-27-2008, 09:11 PM
235/60 16s fit great. I had no rubbing, and it filled out the fenderwell a little more
"WHAT CONE?!?!
post #15 of 16 (permalink) Old 01-28-2008, 08:57 AM
imo the 235/60/16s are preferable over stock. I've never heard anyone having issues with them and they fill the wheel well out an extra 0.5" or so too. imo it should have been the stock tire size for the 16" wheels.
Southpaw is offline
post #16 of 16 (permalink) Old 01-28-2008, 02:44 PM
ThunderB's Avatar
They'll be a little too small diameter for a non-lowered Bird. A stock Bird has too much fender gap with the 225/60R16 and the 235/55R16's are a half inch smaller in diameter. I run them on my lowered Bird.
Biggest porblem with them is the selection is poor, plus they cost more than the 225/60R16 and 235/60R16.
97 T-Bird Sport: Dynomax catback, Removed silencer w/ K&N panel, DReinhart chip, Lightning AGSF12-FM1 plugs/180 stat, Tokico 1.25" dropped stance, bye bye fender gap
'79 F100 SB : 300 ci six, Hurst Mastershift 3spd floor shifter, Offenhauser intake, Holley 4 brrl, EFI manifolds, Chebbie Rockers, Summit Racing 3.50 gearset, DISO 2.5" diesel muffler and 2.5" exhaust, Its'a six?!
ThunderB is offline
