rims sizing - TCCoA Forums
post #1 of 7 (permalink) Old 01-17-2008, 11:48 PM Thread Starter
sloth92's Avatar
rims sizing
I am going to do a 5x4.5 rotor swap on my wifes 95 cougar and I was curious if I could fit 17x9 rims on the front and 17x10 rims on the back also I wanted to know if I was able to do these rims could I fit 300 or 315 tires on the back.
Got the only bird with Lambo Doors in Texas!
Thanks Luke!
97 Thunderbird 4.6
1992 Merc. Cougar 5.0
1995 Merc. Cougar 4.6
sloth92 is offline
post #2 of 7 (permalink) Old 01-18-2008, 12:05 AM
no idea on the rear, but 17x9 on the front will work
post #3 of 7 (permalink) Old 01-18-2008, 12:14 AM
94fastbird's Avatar
Send a message via MSN to 94fastbird
do u know the backspacing? i wouldn't see why not theres a guy on here running 17x 10.5 saleen style rims. i think the back spacing on those wheels are 36mm
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #4 of 7 (permalink) Old 01-18-2008, 12:36 AM Thread Starter
sloth92's Avatar
24mm offset for the front and 27mm for the back also do you think I can get 315s on the back for the fron I will just use 275s
Thanks Luke!
97 Thunderbird 4.6
sloth92 is offline
post #5 of 7 (permalink) Old 01-18-2008, 06:11 PM
Refrigerator Raider Hater
GreenBird's Avatar
you'll have to do some extra work to get more than a 255 on the front and a 295 on the rear.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #6 of 7 (permalink) Old 01-19-2008, 10:38 AM Thread Starter
sloth92's Avatar
like what roll the fenders
Thanks Luke!
97 Thunderbird 4.6
sloth92 is offline
post #7 of 7 (permalink) Old 01-20-2008, 11:54 PM
TCCoA Wheel Guru
The fronts are going to be hanging WAY out...I would have to suggest a 17X8 front wheel with that same spec and you will be fine. Otherwise its going to look totally WRONG.
Brad
1990 & 1994 SC's
cudaz101 is offline
