Tire size advice - 215 to 255 (rear) - TCCoA Forums
post #1 of 17 (permalink) Old 01-24-2008, 07:41 AM Thread Starter
Andy625UK's Avatar
My 'bird has 215/70/15's at the moment that need replacing. I am on a tight budget, and have found a pair of 255/60/15's which I am thinking about buying and putting on the rears with a pair of 215/70/15's (that I have stored in the garage) on the front.
I know of one other person that has a similar combination on here, and I was wondering what other people thought? The o/d's are approximately the same, but I am a bit worried as to whether the extra width on the rear will affect anything else (ride quality/handling).
"...put me on a highway, show me a sign, and take it to the limit one more time"
The Eagles
1975
http://www.cardomain.com/ride/2149821
RIP Dutch T-Bird (Robert Hendriks) 1970-2012 No doubt looking down on us from his low-riding T-Bird in the sky.
Andy625UK is offline
post #2 of 17 (permalink) Old 01-24-2008, 08:35 AM
That size will (just) fit on your 6.5" wide wheels... but i'm not sure about clearance issues. The miata tire size calculator shows them to be a little wider then 235/60/16's and nearly identical in height (.1" diff).
Southpaw is offline
post #3 of 17 (permalink) Old 01-24-2008, 08:51 AM Thread Starter
Andy625UK's Avatar
94MN1246 has 255's fitted to his car and has a pic in this thread: http://forums.tccoa.com/showthread.php?t=106701. He doesn't mention any clearance issues.
The Eagles
1975
post #4 of 17 (permalink) Old 01-24-2008, 08:52 AM
fast Ed's Avatar
Generally speaking, the extra rubber on the rear might cause some understeer (front end losing traction first under hard cornering). Depending on your driving style, you may or may not notice that. Upping the front tire pressure a few pounds compared to the front would make it less noticeable.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #5 of 17 (permalink) Old 01-24-2008, 09:05 AM
I assume you meant to say 94fastbird.
Southpaw is offline
post #6 of 17 (permalink) Old 01-24-2008, 09:28 AM Thread Starter
Andy625UK's Avatar
Yes, sorry! I'd like to see a picture of his car from the rear.
The Eagles
1975
post #7 of 17 (permalink) Old 01-24-2008, 11:13 AM
Traveler's Avatar
I was always told that 245's are the biggest you could (safely) go on the stock 15" wheel.
I have used 245/60/15's and they look and drive great.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #8 of 17 (permalink) Old 01-24-2008, 11:43 AM
I wondered about that earlier but according to tirerack.com BFGoodrich and Goodyear spec a 6.5" min. / 10" max. rim width for their 255/60/15s. Firestone on the other hand says 7" ~ 9" and Dunlop 7" ~ 10".
All on them base their measurments on a 7.5" width.
Southpaw is offline
post #9 of 17 (permalink) Old 01-24-2008, 11:51 AM
94fastbird's Avatar
Send a message via MSN to 94fastbird
i'm gonna try to get some pics of rear this weekend. it at my friends house 50 miles away. getting ready to go in the garage for body work, body kit , paint and wheels. but i'll post some pics with the rear. before i put the news wheels on
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #10 of 17 (permalink) Old 01-24-2008, 11:54 AM
94fastbird's Avatar
no i dont have any clearance issues, but it did give it a nice stance, theres about 1- 1/1/2 fender well gap i'm thinking. i'll have to go down. i miss my car already. haven't had it for 2/1/2 months cause of snow.
Current Mods:
Future Mods:
post #11 of 17 (permalink) Old 01-24-2008, 01:55 PM Thread Starter
Andy625UK's Avatar
Thanks for the info. Sounds like they're worth a try. The 255's are on Ebay over here at the mo. 215's are slightly harder to get hold of for some reason.
Fastbird, if you do get a chance to post some pics I'd be very grateful.
The Eagles
1975
post #12 of 17 (permalink) Old 01-24-2008, 07:45 PM
I run 255/60-15's on the rear of my 94, with 245/60-15's on the front. Though I run those on 15x7" wheels. IMO, a 255 tire on a 6.5" wheel is pushing it.
Here are a couple older pictures, but you get the idea:
-Rod
post #13 of 17 (permalink) Old 01-25-2008, 04:40 AM Thread Starter
Andy625UK's Avatar
-Rod
Thanks for the pics Rod, with 2nd thoughts I think you're right about them being a bit wide for a 6.5" wheel. I spoke to a tyre shop yesterday who pretty much said the same.
The Eagles
1975
post #14 of 17 (permalink) Old 01-25-2008, 05:08 AM
jnk3846's Avatar
Go with a 245, Check my Cardomain page for pictures.
jnk3846 is offline
post #15 of 17 (permalink) Old 01-25-2008, 10:39 AM
i agree with traveler.
i have used 245/60/15 for a long time....highly recommend that size on stock tbird fan wheels.
1994 Thunderbird - Renegade Racing Long block, TFHS Trans, NA/SVO intake. Cam94 lives!
2010 Shelby GT500 - Black/Silver
1995 Thunderbird LX - 2000 GT PI Swap by W&S Motorsports - Sold on Tccoa.
Bill H is offline
post #16 of 17 (permalink) Old 01-25-2008, 01:44 PM Thread Starter
Andy625UK's Avatar
Yeah I think I'll take your advice. Thanks guys.
The Eagles
1975
post #17 of 17 (permalink) Old 01-25-2008, 08:02 PM
235/60/15's here. The picture below was taken before I lowered the car 1.6" with Vogtland springs.
There's a great article HERE that discusses the difference between 235's and 245's
I read this article, specifically the "Changing tire size on stock rims" section, and based my decision to go with the 235/60/15's on it.
If you want to go with the 245's they'll obviously work too. Like racecougar said, a 255 tire on a 6.5" wheel is pushing it.
