245/55/16 - TCCoA Forums
post #1 of 6 (permalink) Old 03-20-2008, 12:58 PM Thread Starter
strung's Avatar
245/55/16
im thinking of ditching my 225/60/16's for some 245/55/16's....my tire shop (les schwab) advised not running any wider tire than a 225 on a 7in wheel....but ive seen plenty of pics of members doing this....the reason im going with a 55 series is because with the 245 its the exact same height as my current tires.....and im not sacraficing any more wheel well gap....so what the verdict?
pimp'n aint easy
mods: air silencer delete w/ k&n panel filter, magnaflow di/do tru duals w/all cats removed, sct 92 oct tune by blue oval chips, tokico advanced handling suspension kit
strung is offline
post #2 of 6 (permalink) Old 03-20-2008, 12:59 PM
Traveler's Avatar
Sounds great except for one thing. Good luck finding a 245/55. I went with a 245/50. Easier to find, cheaper to buy, and VERY close to the same size.
I think there are some "Sport Truck" tires in a 245/55
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 6 (permalink) Old 03-20-2008, 01:17 PM
fast Ed's Avatar
If you're looking for a higher end tire, that size is available in the Toyo Proxes T1R. Their specs show a range of 7.0 to 8.5" wheel for the 245/55R16.
http://marktg.toyotires.com/file/18966.pdf
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #4 of 6 (permalink) Old 03-23-2008, 09:55 PM
Xan
Alot of tire dealers have thier own opinion on what tires you should have on your car. I've evan had a place (sears) tell me they woln't sell me a set of tires cause they said the tires are not as strong... (all though the ones i picked had a higher load rating. They were wider and a shorter side wall.) If you run into people that treat you like that you should just walk out and find a better shop.
Xan is offline
post #5 of 6 (permalink) Old 03-23-2008, 10:57 PM
ok so whats the deal here... is the 96-97 mn12 have a wider rim? because my 89,93,and 95 all have 6.5" rims bead to bead... is there something im missing here? lol
stickysilvertbird is offline
post #6 of 6 (permalink) Old 03-29-2008, 02:44 AM
CrystalPistol's Avatar
Smile
The 15" wheels are 6.5 inches wide, but as far as I know all the 16" wheels that came on these cars are 7 inches wide.
CrystalPistol is offline
