45 MM Too much or too little offset? - TCCoA Forums
post #1 of 6 (permalink) Old 05-23-2008, 05:19 PM Thread Starter
EvilMooseofDoom's Avatar
Howdy...I am taking a casual glance at some local 18x8 wheels, with a 45 mm offset...will these fit, or go in/out too far on the thunderchicken?
Larry
EvilMooseofDoom is offline
post #2 of 6 (permalink) Old 05-23-2008, 05:50 PM
95_SilverBird's Avatar
I think you need something a little closer to 35mm.
Eibach 1.5" Lower Springs, Koni Adjustable Shocks, SCP IRS Brace, SCP Lower Engine Cradle Brace, Mark VIII LCAs
Chuck's Poly Motor Mounts, 13" PBR Front and Cobra rear brakes, 245-45-18 ADR Kasai Wheels, RichardM Intake Tube
Super Coupe leather seats and console, Pioneer Head, Audison Amps, Boston SL Components, 10" Boston G5 subs, Reverse Glow EL Gauges, Super Coupe Ground Effects, '96 Hood and Headlights, Custom paint: Tungsten Silver, PI Intake, 4000 stall
95_SilverBird is offline
post #3 of 6 (permalink) Old 05-23-2008, 11:25 PM
SC V8 Bird's Avatar
Send a message via Yahoo to SC V8 Bird
36 to 42 IIRC
SC V8 BIRD
TCCoA Gallery
http://forums.tccoa.com/vbpicgallery.php?do=view&g=45
Car Domain
http://www.cardomain.com/ride/2527375
NW Late Model Thunderbirds & Supercoupes Myspace Group
http://groups.myspace.com/nwlatemodelthunderbirds
SC V8 Bird is offline
post #4 of 6 (permalink) Old 05-24-2008, 04:45 AM
yes you are correct. According to the Sticky 36mm to 42mm. I'm about to do 40mm. Hope they work out.
FunktasticLucky is offline
post #5 of 6 (permalink) Old 05-24-2008, 11:49 AM
Refrigerator Raider Hater
GreenBird's Avatar
Actually they will have less backspacing (4mm) than an 18x9 ET36 wheel, so they should fit. They will "stick out" 12mm more than a stock 15x6.5" wheel. add a 5mm wheels spacer and you'd be all set.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #6 of 6 (permalink) Old 05-25-2008, 10:39 AM
45mm will not fit the front,it rubs on the spindle,but the back looks like it fits fine,the reason i know is i took my buddys 2008 17 inch bullits off his car which are 45mm and tried them on my 93 cougar and that was the results.my guess would be to go from a 38 to 40mm offset which would be right in the ballpark.
IBEMERCUN is offline
