I need some help finding the correct size tires for my new rims - TCCoA Forums
post #1 of 4 (permalink) Old 06-08-2008, 10:03 PM Thread Starter
dwinthrup's Avatar
They are; Front 18 x 9" - 24mm / Rear 18 x 10" - 22mm - 5 on 4.5. I'm doing the hub conversion and these are the rims I decided upon, I fully expect to have to put spacers on. Now to the fun part what size wheel spacers should I get, what size tire is recommended for the front to avoid rubbing, same with the rear but I would like the rear to be slightly taller then the front.
dwinthrup is offline
post #2 of 4 (permalink) Old 06-09-2008, 03:57 AM
TCCoA Wheel Guru
Spacers for what?? You will be nowhere near hitting anything but the Curbs and fenders. Scratch them off your list you won't need them.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #3 of 4 (permalink) Old 06-09-2008, 06:33 AM Thread Starter
dwinthrup's Avatar
Brad
are these going to fit under my car correctly or even at all?
post #4 of 4 (permalink) Old 06-09-2008, 08:45 PM
TCCoA Wheel Guru
Hit me up with an email @ thecustomwheelshop.com or my personal mail @ [email protected]
Give me all the specifics...The wheels you have spec'd out above are going to look wrong on the car. Thats my honest opinion. There might be a better wheel spec in the same wheel though. I can help you with that.
Cheers
Brad
1990 & 1994 SC's
cudaz101 is offline
