Where to get longer wheel studs - TCCoA Forums
post #1 of 14 (permalink) Old 06-10-2008, 09:23 PM Thread Starter
CobraRThunder's Avatar
Anyone had any luck finding a replacement wheel stud in a longer length? Looking for some for my front hubs.
Thanks in advance, Chris
4R70W From DirtyDog
CobraRThunder is offline
post #2 of 14 (permalink) Old 06-10-2008, 09:31 PM
funny that you ask this now, i was given this site as im in a similar situation
www.wheeladapters.com
rzibilske77 is offline
post #3 of 14 (permalink) Old 06-11-2008, 03:09 PM
Like Titles Matter
kdanner's Avatar
I used ARP studs, they came from either Summit or Jegs.
1998 GT - [email protected]
generated by sloganizer.net
kdanner is offline
post #4 of 14 (permalink) Old 06-11-2008, 06:30 PM
VicRattlehead's Avatar
i used ARP studs, they came from Summit
CMP Drag Racing
VicRattlehead is offline
post #5 of 14 (permalink) Old 06-11-2008, 08:54 PM Thread Starter
But you're running mustang hubs up front right? I have the hub swapped rears, and MN12 fronts. SVT bird wheels in front (17x7), and Mustang R58 (17x9) rears.
4R70W From DirtyDog
post #6 of 14 (permalink) Old 01-10-2011, 04:21 PM
whats the knurl size of the ARP 3" longstuds with the quickstart? i had the info, ive got them on the car already but need to replace one side. need new studs to go along with it. and i cant remember what ones i ordered the last time.
nevermind, figured it out. found the reciept from summit when i got them
Brand ARP
Manufacturer's Part Number 100-7703
Part Type Wheel Studs
Product Line ARP Wheel Studs
Summit Racing Part Number ARP-100-7703
UPC 672036000417
Wheel Stud Style Press-in
Thread Size 1/2-20 RH in.
Knurl Diameter (in.) 0.625 in.
Underhead Length (in) 3.500 in.
Knurl Length (in) 0.400 in.
Quick-Start Nose Yes
Quantity Sold as a set of 5.
Notes Fits Ford rear disc brake and Chrysler front brake applications.
future search refrence 3-1/2" 3.5" wheel stud lug stud knurl size arp wheel studs
CMP Drag Racing
post #7 of 14 (permalink) Old 01-10-2011, 07:54 PM Thread Starter
Those are part numbers for a mustang hub, or thunderbird hub lug hole.
4R70W From DirtyDog
post #8 of 14 (permalink) Old 01-10-2011, 08:01 PM
If I remember right they are correct rear and need redrilled to 39/64 front hubs for a mustang
CMP Drag Racing
post #9 of 14 (permalink) Old 01-10-2011, 08:04 PM Thread Starter
what? Are you drinking? That didn't answer my question Keith
4R70W From DirtyDog
post #10 of 14 (permalink) Old 01-10-2011, 08:07 PM
I said mustang but u have to drill the hub to make em fit.
And no not drunk...yet
CMP Drag Racing
post #11 of 14 (permalink) Old 01-10-2011, 08:10 PM Thread Starter
Well crap, you would think they would have a direct replacement for mustangs.
4R70W From DirtyDog
post #12 of 14 (permalink) Old 01-10-2011, 09:39 PM
tbirdtess's Avatar
Hi
Why do you need longer studs?
I use Moroso 3" studs, rears. 46185 wheel studs.(1/2x20)
Kept the stock Mustang fronts. I use 1" lug nuts!
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #13 of 14 (permalink) Old 01-10-2011, 09:53 PM
Originally Posted by tbirdtess View Post
Hi
NHRA requirement.
post #14 of 14 (permalink) Old 01-11-2011, 12:05 AM
coggonobrien's Avatar
i used the arp as well in my mustang hubs, redrilled out the wholes with the correct bit which i believe is 15.75mm. you can order the bit which is about 30 or 40 bucks. they don't seem to exist for a 1/2 inch drill chuck so I turned mine down in a lathe.
David
coggonobrien is offline
