BFG Drag Radials - TCCoA Forums
post #1 of 3 (permalink) Old 07-04-2008, 02:49 PM Thread Starter
Scott Suzanne's Avatar
Send a message via Yahoo to Scott Suzanne
BFG Drag Radials
I put a set of BFG DR's on the car and noticed that the tire shop mounted them backwards. On the side wall it says mount this side in, and that is facing out. I am going to take it back and get them mounted correctly.
My question is why does it matter which side is mounted in? If I swap them left to right, they would turn the opposite direction, but they would still be mounted backwards. I don't think that they are directional tires. Is there something in the constuction that would necessitate them to be mounted a certain way?
Also, what pressure is everyone running for street and strip? I am at about 27-28 psi now, but I don't want to play too much untill I get the tires swapped around.
Thanks.
Scott
97 Mercury Cougar "Project Eliminator" 385 RWHP 400 RWTQ
2000 GT PI 4.6 Liter with Coil-on Plug Mod, Tork Tech Inc. M112 Supercharger
BC-Automotive 4R70W and Torque Converter by Darrin, 3.73:1 rear gear, Aluminum Driveshaft,
Kooks 3/4 Length Headers, Custom Mandrel-Bent Exhaust, Vogtland 3/4" Lowering Springs,
18x9.5 GT500 Wheels, 255-45-18 front 285-40-18 rear by Custom Wheel Shop.
Under Construction
2010 Mustang GT
Daily Driver / Stock
Scott Suzanne is offline
post #2 of 3 (permalink) Old 07-05-2008, 06:56 PM
ZackG's Avatar
They'd have to be directional, only reason why it'd say that. and I run much lower at the strip than 27. It's been a while but i do remember it being lower than 23 at the strip. On the street, what you're at now is fine.
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #3 of 3 (permalink) Old 07-05-2008, 10:31 PM Thread Starter
I got them swapped around today. They have an asymmetrical tread pattern on them, not directional.
Thanks for the pressure info. They seem to do alright on the street at 27-28 psi. I will lower them down a bit at the track when I make it there.
Scott
Under Construction
2010 Mustang GT
