Mustang 2005+ Bullits - TCCoA Forums
post #1 of 15 (permalink) Old 07-17-2008, 09:10 PM Thread Starter
tbirdmedic's Avatar
Hey guys and gals
I have all the parts to do the mustang hub swap and the Cobra Brake install on my '95 S/C. I have found some rims I really like and was wondering if anyone else has installed 2005+ Mustang rims on their 'Birds? My question is, since they have a bit too much positive offset, what size spacersa did you use? And if anyone else has used the Bullits, a pic would be a great help.
TbirdMedic
1995 SUPERCOUPE 5-SPEED
'95 LX with a few mods
tbirdmedic is offline
post #2 of 15 (permalink) Old 07-18-2008, 03:16 AM
Baby Huey
warmaster259's Avatar
Talk to Big Mike here on these boards
Jim
warmaster259 is offline
post #3 of 15 (permalink) Old 07-18-2008, 07:09 AM
Should work find as is. Only pictures I have seen of the bullits is someone who used adapters to go from 5 on 4.25 to 5 on 4.5, but there are others I have seen running other styles of 05+ Rustang wheels.
Bangster is offline
post #4 of 15 (permalink) Old 07-18-2008, 07:42 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
if they are the same size and offset as mine, then they would look something like this:
before mounting the tires, double check your wheel to front spindle clearance. mine is about 1/4". i didnt use any spacers in the rear. are yours a 45mm offset?
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 15 (permalink) Old 07-18-2008, 10:47 AM
nickleman60's Avatar
My friend had a couple of '05 bullits and he wanted to see if they cleared on a mn12 so I put them on my '94 and the cleared...
http://forums.tccoa.com/showthread.php?t=89405
94 SC AUTO - $$$$ Pit
nickleman60 is offline
post #6 of 15 (permalink) Old 07-18-2008, 07:03 PM Thread Starter
tbirdmedic's Avatar
Sorry about that. I bought them before I got my Supercoupe in preparation for the swap. Just need to get some rims and tires and on they will go. I will keep an eye out for the parts for you, though. Do you attend our SCCoO meetings at all?
The ad says they are takeoffs and have never been driven, He has 12 of them at $225, if he ever answers my emails!!!!!!!!!!!!!!!
BTW, they are 17"
TbirdMedic
post #7 of 15 (permalink) Old 07-18-2008, 07:05 PM
those sit in really far in the back
post #8 of 15 (permalink) Old 07-18-2008, 07:10 PM Thread Starter
tbirdmedic's Avatar
Thats why I was thinking maybe a spacer would be needed. I will have to see.
TbirdMedic
post #9 of 15 (permalink) Old 07-18-2008, 07:16 PM Thread Starter
tbirdmedic's Avatar
BIG MIKE
Thanks for the pics and the info, and all the other guys as well. My car is blue, and I think these will look hot on her.
TbirdMedic
post #10 of 15 (permalink) Old 07-19-2008, 10:36 AM
Motorboatin' SOB
big mike's Avatar
high offsets will do that. i recently swapped on my original 17's.
2014 GT
1990 300ZX TT
big mike is offline
post #11 of 15 (permalink) Old 08-08-2008, 05:34 PM
arent the 05-08 wheels better offset for our cars then the 94-04?
staffamerica74 is offline
post #12 of 15 (permalink) Old 08-09-2008, 10:02 AM
Motorboatin' SOB
big mike's Avatar
if by better, you mean following the body lines, then no. my 96-98 gt wheels are more flush with the body than the 05+ ones.
2014 GT
1990 300ZX TT
big mike is offline
post #13 of 15 (permalink) Old 08-10-2008, 02:24 PM
i mean by more wheel clearance. so you can get a bigger wheel under it. I think if you get a 10 inch 05 stang wheel its got very close to the same offset as the 10 inch wheels made for our cars. Currently I have 98 cobra wheels on mine and they look to fit pretty well but I did have some rubbing with 255 45 17 in the rear before I went with Bilsteins.
post #14 of 15 (permalink) Old 08-11-2008, 07:54 AM
Motorboatin' SOB
big mike's Avatar
well, i can tell you that i test fitted a 10 inch wheel with no tire in the 94-04 offset, and it stuck out alot. i believe it was a 24mm offset. if they had a 10 inch wheel in the 05+ offsets, i would have test fit that one.
2014 GT
1990 300ZX TT
big mike is offline
post #15 of 15 (permalink) Old 08-12-2008, 06:05 PM
yeah the 05-07 offset for a 10 inch wheel is normally a 40mm to 45mm offset. I am not sure if that will clear the sway bar or not tho, especially my addco bar.
