275/50/15 drag radials...will they fit? - TCCoA Forums
post #1 of 11 (permalink) Old 08-01-2008, 12:38 PM Thread Starter
KevinM's Avatar
Send a message via AIM to KevinM
I am looking for a set of drag radials and I found a really good deal on a set of 275/50/15 BFGs. I was wondering if these will (a) fit on a factory 15" wheel, which I am assuming isn't but like 6" wide or so, and (b) will the width clear all suspension and other components in the rear?
Kevin M
KevinM is offline
post #2 of 11 (permalink) Old 08-04-2008, 11:40 PM
MAMN12 Posse Member
JeffTBird93's Avatar
Yes, I've got a set that size mounted on stock 15's.
~Jeff
*signed off
JeffTBird93 is offline
post #3 of 11 (permalink) Old 08-05-2008, 12:07 AM
Scott Suzanne's Avatar
Send a message via Yahoo to Scott Suzanne
I just burnt through a set of BFG Drag Radials on mine really quick. The street will eat them up if you do a few burn outs. That is a really soft tire and the rubber comes off in chunks. I would save them for the track if you get them. I personally won't buy another set. I am thinking of some M/T Street ET and just running them at the track.
Good luck.
Scott
97 Mercury Cougar "Project Eliminator" 385 RWHP 400 RWTQ
2000 GT PI 4.6 Liter with Coil-on Plug Mod, Tork Tech Inc. M112 Supercharger
BC-Automotive 4R70W and Torque Converter by Darrin, 3.73:1 rear gear, Aluminum Driveshaft,
Kooks 3/4 Length Headers, Custom Mandrel-Bent Exhaust, Vogtland 3/4" Lowering Springs,
18x9.5 GT500 Wheels, 255-45-18 front 285-40-18 rear by Custom Wheel Shop.
Under Construction
2010 Mustang GT
Daily Driver / Stock
Scott Suzanne is offline
post #4 of 11 (permalink) Old 08-08-2008, 04:46 PM
Send a message via AIM to bigpoppa822
Will 15" wheels fit on Supercoupes too?
1990 Thunderbird SC
HP: 250
TQ: 361
1/4: 14.3 @ 97.5 <- first time ever doing a pass
bigpoppa822 is offline
post #5 of 11 (permalink) Old 08-08-2008, 04:57 PM
fast Ed's Avatar
Yes they will, same size brakes as the LX.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #6 of 11 (permalink) Old 08-18-2008, 06:20 PM
shaken, not stirred
stangboy7's Avatar
275s will fit 15s? I thought the 245s i got barely fit on my 16s. Is there enough clearence in the wheel well for 275s? I think i remember that it was said that 275s wouldnt fit in the front due to clearence issues?
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #7 of 11 (permalink) Old 08-18-2008, 06:24 PM
MAMN12 Posse Member
275's won't fit in the front. I previous had 275 MT ET streets for drag radials...and currently run a 275 Nitto every day.
~Jeff
*signed off
post #8 of 11 (permalink) Old 08-18-2008, 06:38 PM
shaken, not stirred
stangboy7's Avatar
Any modifications needed to run 275 in the rear?
C.Hill
- Henry Ford
- Thomas A. Edison
post #9 of 11 (permalink) Old 08-18-2008, 08:33 PM
MAMN12 Posse Member
They rub a little bit so I'd recommend rolling the fenders. Other than that no. I'm even lowered so I've only got about 1.5" clearance.
~Jeff
*signed off
post #10 of 11 (permalink) Old 08-18-2008, 09:05 PM
shaken, not stirred
stangboy7's Avatar
Well I would only use them for track use, so as long as it doenst rub too bad, I should be ok?
C.Hill
- Henry Ford
- Thomas A. Edison
post #11 of 11 (permalink) Old 08-18-2008, 09:10 PM
MAMN12 Posse Member
Yeah, mine just rub on speed bumps and things like that.
~Jeff
*signed off
