What other center caps will fit my fanblades? - TCCoA Forums
post #1 of 11 (permalink) Old 11-22-2008, 06:56 PM Thread Starter
Sean T.'s Avatar
Hi there, I am a new member, and I just bought a set of fanblades for on my Taurus.
Seeing as the fanblades have a T-bird logo on them, I would like to get a different set of center caps.
So far, I know that the super coupe exposed-lug caps:
Taurus SHO slicer caps:
and Taurus exposed-lug caps (which I hear are exactly the same as the SC ones):
Those will all fit, but are there any other options?
And can someone explain to me the difference between the years and models of the center caps so I know what to search for?
Sean T. is offline
post #2 of 11 (permalink) Old 11-22-2008, 08:20 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Actually the center caps in the first pic are specific to 96/97 Sport wheels. The '93-'95 SC centercaps are the same as the LX fanblade center caps.
The metal caps for the 16" Turbo Coupe snowflake wheels will fit but they have a T-bird logo imprint on them as well.
tinman_72 is offline
post #3 of 11 (permalink) Old 11-22-2008, 08:48 PM Thread Starter
Sean T.'s Avatar
ohhhhh, I knew I had seen SC wheels with the same caps I have, but then I found this picture, so I just figured there was two different caps offered or something.
Sean T. is offline
post #4 of 11 (permalink) Old 11-23-2008, 08:08 PM
CobraRThunder's Avatar
Those Centercaps will fit. Fox body mustang center caps.
4R70W From DirtyDog
CobraRThunder is offline
post #5 of 11 (permalink) Old 11-24-2008, 08:11 PM Thread Starter
Sean T.'s Avatar
Did those come in anything other that chrome? I want something that will look like it belongs on the wheels.
I just finished putting them on... please excuse the dirt, I needed new tires really bad and it started snowing real bad today so I did't get a chance to clean them before I got the tires mounted...
um, why won't it post the actual pictures?
Sean T. is offline
post #6 of 11 (permalink) Old 11-25-2008, 03:06 PM Thread Starter
Sean T.'s Avatar
Mrrrr.... I got some of the Sport/Taurus center caps... put them on and I don't really like them much. :-\
Sean T. is offline
post #7 of 11 (permalink) Old 12-01-2008, 05:35 PM Thread Starter
Sean T.'s Avatar
Anybody know if the caps on these will fit?
Sean T. is offline
post #8 of 11 (permalink) Old 03-12-2009, 09:20 AM Thread Starter
Sean T.'s Avatar
Are these the mustang caps that will fit?
eBay Item number: 380109369452
And these will fit on the SC wheels too, right?
Sean T. is offline
post #9 of 11 (permalink) Old 03-12-2009, 09:29 PM
The_Ghost's Avatar
Sorry to threadjack but is there a set of exposed lug centercaps for EARLY style SC wheels?
Best,
Ghost
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #10 of 11 (permalink) Old 03-12-2009, 10:15 PM Thread Starter
Sean T.'s Avatar
Are those the early style SC wheels? Do they have the same size center caps as the fanblades?
If so, then the Taurus 5-hole caps and the Sport 5-hole caps (both in first post) should fit.
Sean T. is offline
post #11 of 11 (permalink) Old 03-13-2009, 02:12 PM
The_Ghost's Avatar
Sport caps won't match though because of the contours but yes it is the style of wheels you pictured
