Rotating tires mounted on fanblades? - TCCoA Forums
post #1 of 7 (permalink) Old 11-24-2008, 11:43 PM Thread Starter
Sean T.'s Avatar
I just got a set of fanblades and when I put them on my car, I realized they are all labeled RH, RR, LH, LR...
So what should I do when it's time to rotate them? Do you guys have any method that you follow for directional wheels so they don't get all mis-matched? (i.e. RH and LH on same side)
Sean T. is offline
post #2 of 7 (permalink) Old 11-24-2008, 11:58 PM
When it comes to directional tires or wheels i just go front to back-back to front.
post #3 of 7 (permalink) Old 11-25-2008, 01:37 PM
Changing sides was the norm when all tires were bias-ply. The pattern was actually kind of a bow-tie that included the spare (if full-sized). This changed when radials started coming out in the 70s.
Radial tires are rotated front-back on the same side. The directional wheels just make it obvious when this is not followed.
Those who live by the sword get shot by those who don't.
TeflonJon is offline
post #4 of 7 (permalink) Old 11-25-2008, 02:03 PM
yep.....even my 73 thunderbird owner manual tells you to rotate all of them including the spare..
post #5 of 7 (permalink) Old 11-25-2008, 02:08 PM
As did my first car - a 1974 Monte Carlo.
Bias-ply was king in them thar days.
post #6 of 7 (permalink) Old 11-25-2008, 02:19 PM
heh, I still have a bias ply for the spare(the actual original firestone from when the car was new).
post #7 of 7 (permalink) Old 11-25-2008, 03:04 PM Thread Starter
Sean T.'s Avatar
Ohhhhhhhhh ok. Thanks
Sean T. is offline
