wheel adapters - TCCoA Forums
post #1 of 9 (permalink) Old 12-11-2008, 06:08 PM Thread Starter
wheel adapters
hey guys wondering what a suitable metal would be to make wheel adapters out of. my brother wants to run GM wheels on his dakota r/t and asked if i could make them at work on the mill. easy enough to program and make it just getting the spacing and pattern correct.
all i know is prob about 1" thick. wants to do this because most of the adapters do not have a ring to support the rim, only supported by the lug studs and the ones that have the ring are expensive i guess.
thanks for any help. and yes i suggested a hub swap and said he that was expensive as well.
Dean
1993 3.8L Tbird----sold
1994 4.6L Tbird----sold
1995 Mark VIII----sold
2004 Mustang GT----sold
2003 Mach 1----current
smitty2919 is offline
post #2 of 9 (permalink) Old 12-11-2008, 06:29 PM Thread Starter
maybe Cudaz101 could chime in with some expertise/opinion?
post #3 of 9 (permalink) Old 12-11-2008, 06:59 PM
there isnt a metal on earth strong enough to make them a good idea
post #4 of 9 (permalink) Old 12-11-2008, 08:07 PM
lowbird96's Avatar
agreed maybee have the hubs drilled to the corect pattern, or trade for the right set of rims
third birds the charm.. I HOPE
lowbird96 is offline
post #5 of 9 (permalink) Old 12-12-2008, 10:58 AM
TCCoA Wheel Guru
I have nothing to add that has not already been said all or in part.
Advice would be to simply find something that fits correct. Sooooo many options available. You would likely have more money into the wheels & spacers than if you just bought something that worked to begin with.
good luck
Brad
1990 & 1994 SC's
cudaz101 is offline
post #6 of 9 (permalink) Old 12-12-2008, 04:41 PM Thread Starter
my brother had some spacers on his mustang for a while and had no problems, i believe they were H&R or something, hence why i don't see them as a terrible idea. anyone want to share with me exact reasons/bad experiences with them?
not looking for a fight, just never ran into any problems or heard of anything bad first hand, just people saying they are a bad idea
post #7 of 9 (permalink) Old 12-12-2008, 05:46 PM
http://forums.tccoa.com/showpost.php...85&postcount=7
spacers and adapters put too much stress on the studs and can snap them under shock(curbs,putholes, railroad tracks, speed bumps, ect.). they can also prematurely wear out the wheel bearings.
post #8 of 9 (permalink) Old 12-12-2008, 08:25 PM Thread Starter
these will end up being hub centric with a lip. on that link posted by XR7-4.6 did you know what kind of adapters those were??
post #9 of 9 (permalink) Old 12-13-2008, 10:40 AM
94fastbird's Avatar
Send a message via MSN to 94fastbird
m2 brand 6061 t6 billet aluminum 1 inch adapter. wheel adapters work yes, but it does put more stress on lug nuts, because theres only 4- 6 threads at the most holding the adapter on. i dont feel the comfortable with only that many threads holding my wheels and adapter on.
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
