Mustang Wheels - TCCoA Forums
post #1 of 6 (permalink) Old 01-09-2009, 12:41 AM Thread Starter
Sideoiler's Avatar
Mustang Wheels
What is the difference in fitment between the '94 to 2003 Mustang wheels and the 2003 to 2009 wheels? Anyone know? Just curious, trying to help a neighbor.
Thanks!
Sideoiler is offline
post #2 of 6 (permalink) Old 01-09-2009, 08:51 AM
94-04 less backspacing
05-current more backspacing
for example the 08 18x8 factory wheels have 50 mm offset
the 08 17x8 factory wheels have 45 mm offset
the 04 17x8 factory wheels have a 30 mm offset
1.5 and 2 centimeters difference in backspacing.
I guess a little more specific information would be needed to get a good answer.
Bangster is offline
post #3 of 6 (permalink) Old 01-09-2009, 11:35 PM Thread Starter
Sideoiler's Avatar
So....would the newer different offsets fit a 2003 without any major problems?
Thanks!
post #4 of 6 (permalink) Old 01-10-2009, 08:32 AM
jk69cat's Avatar
Thanks!
yes they will fit fine . they just may be a little sucked in . depends on the wheel
mn12 less!
jk69cat is offline
post #5 of 6 (permalink) Old 01-10-2009, 02:28 PM
R8D-XXX's Avatar
I have seen stock 05+ wheels on 94-04 mustangs and it does not look good!! They sit in way to far.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #6 of 6 (permalink) Old 01-10-2009, 05:22 PM
