New Wheels! - TCCoA Forums
post #1 of 19 (permalink) Old 01-17-2009, 07:10 PM Thread Starter
greencurse's Avatar
New Wheels!
I just put down half of the money for these... http://www.carolinarides.com/forum/s...ad.php?t=41645 18x9 Chrome Roush Wheels. I think i have already found the other two centercaps and im not really worried about the lip on the one being messed up but i am worried about this.... http://www.stage3motorsports.com/pro...ang_Wheel.html the part where it says will not fit IRS cars. Im not sure that i have to worry about this and its not like i can do a test fit as i dont have the hubs swapped yet. Anyone had any experience with these?
1997 Thunderbird LX, 4.6L, Performance White.
3.27 TL, 300hp J-Mod, Mid-Mount Magnaflow w/2.25" True Duals to 3" Magnaflow 15* Slash Cut Tips, PI Intake,
FR500 Steering Wheel, FRPP Wires, 180* T-Stat, 22C Plugs, Cobra Vert Rears, RSTB, SC "L" Braces. 175k and still flying!
greencurse is offline
post #2 of 19 (permalink) Old 01-17-2009, 09:30 PM
Nice rims at a good price. Aren't those the 4.5" Mustang bolt pattern? You're gonna need a hub-swap to put them on.
post #3 of 19 (permalink) Old 01-18-2009, 02:19 PM Thread Starter
greencurse's Avatar
Yep Ron, i already have some 10th Anny calipers and some redrilled t-bird rear hubs. Now all i need is the front hubs some front rotors and tires and im set.
post #4 of 19 (permalink) Old 01-19-2009, 12:48 AM
Ex Nihilo's Avatar
uhh...
On that second link, It says it won't fit IRS cars.... Isn't that going to be a problem? If I missed something, then sorry.
-Josh
My Car Domain
"It will be found an unjust and unwise jealousy
to deprive a man of his natural liberty
upon the supposition that he may abuse it."
-George Washington
Ex Nihilo is offline
post #5 of 19 (permalink) Old 01-19-2009, 08:24 AM
CEO, WT Club
GODSPEED's Avatar
That offset is way too low to look good on an mn12. You need something like a +36 offset on a 9" wheel. They will most likely rub badly... and stick out the fenders. I would get your money back and look for some 05+ Mustang aftermarket wheels with a higher offset.
-Joel
Previous MN12s:
GODSPEED is offline
post #6 of 19 (permalink) Old 01-19-2009, 10:56 AM Thread Starter
greencurse's Avatar
thank you... unfortunately this is what i needed to hear but not something i wanted to
i will continue my research
post #7 of 19 (permalink) Old 01-19-2009, 12:01 PM Thread Starter
greencurse's Avatar
I am 99.9% sure they are +28.
the 10 inch wheels are +41.
these are the specs provided by the seller..... i need to ask about the ten inch wheels.... i didn't know about that!
EDIT: all wheels are 18x9's
post #8 of 19 (permalink) Old 01-19-2009, 12:29 PM
CEO, WT Club
GODSPEED's Avatar
The stage 3 motorsports page says +21. I would believe them before some guy that just wants to sell them.
-Joel
Previous MN12s:
GODSPEED is offline
post #9 of 19 (permalink) Old 01-19-2009, 01:07 PM Thread Starter
greencurse's Avatar
I trust what he is saying, These are also not the same as the stage3's as the ones im buying are the older style
post #10 of 19 (permalink) Old 01-19-2009, 03:27 PM
Ex Nihilo's Avatar
ahh,
Originally Posted by greencurse View Post
...... These are also not the same as the stage3's as the ones I'm buying are the older style
See that's the part I was missing. Gl with the new wheels.
-Josh
My Car Domain
-George Washington
post #11 of 19 (permalink) Old 01-19-2009, 03:31 PM Thread Starter
greencurse's Avatar
thank you sir, if they arent perfect i will get some spacers. I guess i will probably be the only bird with roush wheels.
post #12 of 19 (permalink) Old 01-19-2009, 03:36 PM
CEO, WT Club
GODSPEED's Avatar
You need to do more homework on this before you buy. You will not need spacers for wheels that are +28. If anything, you might need to have the wheels milled to a higher offset.
-Joel
Previous MN12s:
GODSPEED is offline
post #13 of 19 (permalink) Old 01-19-2009, 03:56 PM Thread Starter
greencurse's Avatar
okay thanks will do
post #14 of 19 (permalink) Old 01-21-2009, 12:26 PM
R8D-XXX's Avatar
http://www.discounttiredirect.com/di...eelOffsets.jsp
Click on the link and view the positive offset picture. This is why a wheel with more offset will actually sit in more instead of sticking out. Hope this helps. The less offset you have, the more it will stick out.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #15 of 19 (permalink) Old 01-21-2009, 03:14 PM Thread Starter
greencurse's Avatar
yeah it took some studying to figure that out. so since these are +28 for a 9" wheel and the optimal is +36 on a 9" wheel these will stick out a little further than usually desired approximately 1/3".
post #16 of 19 (permalink) Old 01-21-2009, 10:00 PM
R8D-XXX's Avatar
Yes. I think +36 on a 9" wheels sits right at the edge of our cars(maybe out just a tad) The difference between your +28mm and the desired +36mm = 8mm....yeah I went to school LOL. The conversion from MM to inches is about .0393 So 8 x .0393= roughly 3/8"
They are gonna stick out a bit.
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #17 of 19 (permalink) Old 01-21-2009, 10:30 PM Thread Starter
greencurse's Avatar
thats cool, i got them home tonight and man do they shine. no matter what anything shiny is better regardless if they do stick out 3/8"
post #18 of 19 (permalink) Old 01-28-2009, 01:18 PM
CEO, WT Club
GODSPEED's Avatar
Well, you'll be singing a different tune when your fender eats your tire.
-Joel
Previous MN12s:
GODSPEED is offline
post #19 of 19 (permalink) Old 01-28-2009, 01:29 PM
I have to disagree, I'd say a +30mm offset on a 9" wheel sits right at the edge with these cars, 36 almost tucks them in.
My + 26mm offset on my cobra wheels sit out just a tad on the front. Not even 3/8".
