rims - TCCoA Forums
post #1 of 8 (permalink) Old 01-29-2009, 04:00 PM Thread Starter
billboehm's Avatar
rims
likin the torq- thrust 2 No. 405's from american racing in stock 15" for my blue tbird. any opinions?
http://www.tirefactory.com/virtualwheels.cfm
click on "launch virtual wheels" for the rim program!
9mm Spark Plug Wires
MSD Ignition Coils
Mac Cold Air Package
Hypertech Programmed
Magnaflow Mufflers
Clear Corners
Sandblasting any aluminum parts i can get to without removing the engine
SCP 3.5" Cowl hood
and of course, PAINT!!!
billboehm is offline
post #2 of 8 (permalink) Old 01-29-2009, 10:54 PM
white 97 lx's Avatar
Why 15's? I liked them better in 18's, remind me of bullitts. Try the car on 18's, 60 series with a 1" drop on the car.
white 97 lx is offline
post #3 of 8 (permalink) Old 01-30-2009, 09:49 AM Thread Starter
billboehm's Avatar
cuz i can't afford new rubber too.
MSD Ignition Coils
Magnaflow Mufflers
Clear Corners
SCP 3.5" Cowl hood
post #4 of 8 (permalink) Old 01-30-2009, 02:03 PM
That is not a good way to look for wheels
Plus you'll need a hubswap, plus they are $200 a piece, plus none are in an offset that works, ect.
post #5 of 8 (permalink) Old 01-30-2009, 10:41 PM
Are u sure on them not fitting?? because when u use the guide he has posted it shows those rims with a green check mark saying they fit our cars
transam396 is offline
post #6 of 8 (permalink) Old 01-30-2009, 10:49 PM Thread Starter
billboehm's Avatar
ya they used to have that exact same program at a local tire/lube shop.
MSD Ignition Coils
Magnaflow Mufflers
Clear Corners
SCP 3.5" Cowl hood
post #7 of 8 (permalink) Old 01-30-2009, 11:25 PM
http://www.americanracing.com/browse_vintage.asp
I dont see any with a 5x108 bolt pattern
post #8 of 8 (permalink) Old 01-31-2009, 07:34 AM
Who is John Galt?
Moved to Tires/Wheels
"Won't work, can't be done"
cougar_guy04 is offline
